P700 First ride, Fox Shocks
P
PHS79
15
20
Today we took the Pioneer out for the first ride after I installed the Fox 1.5 Podium shocks this week. We went Black River Falls WI, we only put about 60 miles because the girls (7 and 8 years old) wanted to be done. But at least we got out on the trails.
I was pleasantly surprised with the improvement in ride quality over the stock shocks! The trails we were have a lot of sand and get washboarded very easy. With the stock shocks would usually only be able to top out at 25mph before the bounce got to be too much, but with the Foxes on I found myself going 35 or more! The ride was so much improved and they was no "porpoising" in some of the whoops sections of the trails. These shocks really soak up the terrain! My wife rode in front for about 1/2 the ride and let the girls swap into the front the other 1/2, she said the ride in the rear was almost as good as the front.
I never changed the preload on the springs, I just put them on the way they were right out of the box. I have the dial 6 clicks from the softest setting. I did play with the dial a bit and turned it to 10 for softest and then down to 3 clicks. My wife thought that 6 gave the best ride overall, but I will be playing with the dial and preload to see if I can fine tune the ride more.
Are the Fox Shocks worth the $1300 price I paid for them, in our case with my wife having had back surgery last October and having two vertebrae fused, yes they are worth every penny. But even for me without back problems they are still worth it. I would highly recommend them!
63,556
Premium shocks definitely make a world of difference. Did your fox'es come pre-adjusted?
We seen the first few pairs come loose requiring full adjustment.
Thanks.
208,013
Thanks.
Mine came with two tags, one for the front and one for the back, letting you know where all the setting were.
P
PHS79
15
20
Thanks.
Mine already had the preload set, all the jam nuts tight and the measurements on machine were only 1/4 inch lower than with the stock suspension so I just installed them and rode with them the way they came. I think I am going to change the preload and crank them up a bit, probably a little higher than stock.
swsebek
swsebek
2,854
5,828
pa
Fox shocks are "SUPPOSED" to come pre adjusted for your pioneer.... and most guys gain height when putting them on.....I'm loosening my preload in front with my lift kit
GravelBat
GravelBat
34
72
Iowa
Good to hear and thanks for the review. I'm getting ready to pull the trigger on a set but needed some solid reviews from some members here first.
208,013
You won't be sorry!
Reactions: GravelBat
Becht313
Becht313
35
75
New Hampshire
I posted some other pics under mods but here's what I found. No big deal to correct but for the money?? Somebody forgot to test fit...After I cut the dial down to work I'll post a review. Otherwise I'm stuck at medium setting in the front. 1fd724e2c4a871a4c7a0a7f78bec2f078ef3743c8973817245d2e155a4ea5b6e54bd39fb8d3b19195ba465a55f23bf053e5c358ee94b770553cad3e3c709a2a3
Sent from my SM-G965U using Tapatalk
Reactions: swsebek
swsebek
swsebek
2,854
5,828
pa
I posted some other pics under mods but here's what I found. No big deal to correct but for the money?? Somebody forgot to test fit...After I cut the dial down to work I'll post a review. Otherwise I'm stuck at medium setting in the front.View attachment 87264View attachment 87265View attachment 87266View attachment 87267
Yes for the money, you shouldn't have to cut anything. You aren't the first one to notice this. Cutting them down is the easy solution
