I often wonder if the break in particulate is related to the clutch surfaces mating together? I say this because it's not uncommon to see particulate in the first oil change with dirt bikes. After the first it seems to reduce significantly on the bikes.
Does anyone else find the engine oil dipstick next to useless? I put 6.1 quarts in, which is spec when changing both filters, I can't get a clear reading on the dipstick. It's like oil gets on the stick higher up as you remove it and runs down. For the record I changed both the sub transmission and the engine oil so I know I didn't drain the sub transmission and double fill the engine
