Fox Live Valve Indicator not working
cspenc12
cspenc12
10
Garden Grove, CA
  1. Talon X4
I just purchased the 2021 1000X 4 with the Fox shocks and Jackson turbo. I’ve now taken it out twice to realize the suspension indicator (normal/sport) is not lit up on my dash. When I toggle the button nothing happens. I just reached out to the dealership today and waiting to hear back from them. I’m just wondering if anyone else has had or heard of this being an issue. Please let me know. I’m hoping I can get this resolved without taking it in.
PaulF
PaulF
1,462
4,815
When you first turn the key on, ALL the lights on the LV display light up for about 2 seconds as a test (like pictured below). Is yours doing that or is it always blank?...
1614049000577
PaulF
PaulF
1,462
4,815
Yes they all light up for 2 seconds.
That rules out the light panel. Unfortunately I do not have a LV service manual (or a LV for that matter) so I am shooting in the dark. Lets start with the basics...
  • Check all the fuses.
  • Tighten your battery cables (this is a common problem).
  • Make sure the grounds are clean and tight (this is another common problem). There is a bunch under the driver seat, one on the frame below the battery and another on the left side of the engine.
  • Make sure the LV "brain" is completely plugged in and screwed down tight. Not sure if there is a separate ground for this unit or not but look around for one and make sure it is clean tight too. It is under the front cowl above the glove box right under here...
1614059120864
cspenc12
cspenc12
10
Garden Grove, CA
  1. Talon X4
Thanks for your input. I’m going to start with your suggestions to hopefully avoid taking the dashboard apart.
I did download the 2020 Service Manual to find a section troubleshooting the FLV Warning Indicator Circuit. Even though this is not my exact situation, it does troubleshoot the same components and the connections.
Does the normal mode light turn on when the button is pushed and in park? Does the engine need to be running?
23F979FE 281F 4DFE A16B 9272DA9211BF
2E868E63 1913 420D 9B8B CC5C0B76313B
6061DD51 2C7F 44E8 9CDA C15FB67CECAF
HondaTech
The 4 seat LV brain is under the drivers side rear seat. Only the 2 seaters are under the dash panel.
With the indicators turning on at startup, that should rule out the box. Since that is what is running the check for any issues when keyed on. But anything is possible.
Your checklist is a good start though.
cspenc12
cspenc12
10
Garden Grove, CA
  1. Talon X4
After checking the switch on the dash with an ohm meter and confirmed that it is working correctly, I pulled up the backseat to find the SCU was not even plugged in. So I plugged it in, indicators lights came on. Now the FLV indicator light stays on. I jumped the DTC under the front seat with a paper clip. It blinked 6 times. I had no luck erasing the code. If I did erase it, it comes back is e we hat I’m figuring. Anyone know what the 6 blinks mean?
SCU (suspension control unit)
DTC (diagnostics trouble code)
DDF6B4A9 240D 471A A3EB 7B23A399E359
8A199897 BE0B 43B1 9CDF AAC6FF4B9330
  • Wow
Reactions: TripleB and CID
Stilly1155
Stilly1155
79
350
53
Happy Jack, AZ
  1. Talon X4
This is just a guess but maybe it's code 13. 1 light blink and then 3. If so this might help. I think the dealer might have D/C'ed that because they could'nt figure it out. Maybe Honda tech could chime in.
1614441521700
Reactions: TripleB
cspenc12
cspenc12
10
Garden Grove, CA
  1. Talon X4
Well now that you put it like that. It’s 5 blinks 1 light blink. That would be code 51 I’m guessing which is Steering angle sensor CAN communication fault.
DAC2B93E DB6A 4FB9 B9CB C4C0D172ED7E
A2C67BF7 3664 48FF B649 31C9E28F4041
Reactions: TripleB
Stilly1155
Stilly1155
79
350
53
Happy Jack, AZ
  1. Talon X4
I hope you get it all figured out. Please let us know what you find and good luck.
5,488
25,261
The steering angle sensor has caused others’ problems IIRC.
Reactions: Stilly1155
cspenc12
cspenc12
10
Garden Grove, CA
  1. Talon X4
IT’S FIXED. The steering angle sensor was also not plugged in. Just like the SCU. After I plugged everything in I did the steering angle sensor initialization the last blinks were supposed to be 3 times but for me it only did 1. All indicators are on. The warning indicator is off. I just took a spin around the neighborhood in sport mode. Definitely feel the difference. Totally stoked to take out on my next trip to experience the benefits. I took pictures of my homemade jumper below. I actually tried to purchase the tool but it’s unavailable at my location. Thanks for all the help and support!
69158E48 769D 4093 AFCF CE6D2115BE0A
3312F6B3 7C5E 4AC8 B131 3E8965D634D5
34ACBCC9 9E2B 40C5 8016 00CAA1DCC3BF
FBC4F489 89AA 4AA8 8B29 49C7409D7989
Stilly1155
Stilly1155
79
350
53
Happy Jack, AZ
  1. Talon X4
IT’S FIXED. The steering angle sensor was also not plugged in. Just like the SCU. After I plugged everything in I did the steering angle sensor initialization the last blinks were supposed to be 3 times but for me it only did 1. All indicators are on. The warning indicator is off. I just took a spin around the neighborhood in sport mode. Definitely feel the difference. Totally stoked to take out on my next trip to experience the benefits. I took pictures of my homemade jumper below. I actually tried to purchase the tool but it’s unavailable at my location. Thanks for all the help and support!View attachment 257556View attachment 257557View attachment 257558View attachment 257559
Glad to hear it's fixed. Good job!
TripleB
TripleB
15,618
140,491
Caryville, Tennessee
Everyone luvs a happy ending.
