FINALLY getting the rear qs3’s to match my fronts. Should I take off my HL bracket lift at this time and crank the preload of the Fox springs? Or leave the lift on, and have the ride suffer a bit due to the shock angle. I need the extra ground clearance either way, will I get an equivalently s***ty ride with either bracket lift or cranked preload? Is one better than the other?
