P1000 Fox shock difference
116,574
If you have a winch you can always winch yourself up on a tree for the fronts or use a friend winch to tilt you over for the rears.. I have not tried using a snatch block to winch myself to the side to change a rear but that might work too..... but granted you need a friend with a winch or trees
We tried that, witch I’ve done before. The only issue was were in the sand bowl area and the trees aren’t that big. We found a larger tree but the quad just slid in one side of the sand. If it was dirt with some gravel or roots to keep it from sliding it would have ben fine.
tr005
tr005
491
2,660
Big Rapids, Mi.
Yes the winch works well until you build a front rack and don’t put a hole in it to go up thru. Lol
