BWAF
I get paid to pass gas
Thought you had fox shocksJust finished installing 814s on P1K5 ...... 350 on front, 400 on rear.
No I was just debating which to get a few weeks ago. I went with the 814 to get more lift.Thought you had fox shocks
Nice you got picksNo I was just debating which to get a few weeks ago. I went with the 814 to get more lift.
Both shocks can give you the same lift. Just add or take away preload to the spring to get whatever ride height you want.No I was just debating which to get a few weeks ago. I went with the 814 to get more lift.
I thought so, but was not positive. Supposedly, per instructions, these should be set 18 1/2" between center of bolts for best performance. When that was done it lifted my front 2-3" and rear over 1". Pretty sure I could run true 29s, maybe 30s.Both shocks can give you the same lift. Just add or take away preload to the spring to get whatever ride height you want.
If u had it jacked up when u adjusted preload and then lowered it to the ground it will give u a false measurement. Ride it around the driveway and then measure. I had 12.5 but after I rode it was around 11".I adjusted my fronts to 1.5" of preload adjusted from black collar on top to top of spanner nut. I forgot to check initial height of vehicle before I did this and I am curious as to what kind of gain I achieved. Does anyone have measurements of theirs? I now measure 14" clearance to the front factory skid plate. When I measure my rear clearance to the factory skid, it is 12.75". I have some rear fox shocks on the way and am hoping to gain atleast an inch in the rear. Right now I do not like the way it sits. Oh yeah, factory 27" tires on 12" wheels
Snuff, would you happen to know what spring rates come on the fox fronts for both the 3 and 5 seaters.250# Front and 300# Rear on the 5 with Fox's, Elkas and WE's seem pretty good.
Here's some info some other members have found on the stock Fox shocks.Snuff, would you happen to know what spring rates come on the fox fronts for both the 3 and 5 seaters.
1000-3 LE with Fox shocks
Front = 12.5" length, 2.50 diameter, 225# (033-08-032-2)
Rear = 15.25" length, 3.0 diameter, progressive 171/300# (033-09-000-2)
1000-5 fox shocks
Front = 14.5" length 2.5 diameter, progressive 252/350#
Rear = 15.5" Length 3.0 diameter, progressive 187/350#
From what I've saw the progressive upper coil binds or is very close to at ride height.
The specs are for the springs (I updated that). The shock lengths are the same.Huh.... may be a dumb question, but why would the 5 have longer front shocks? Isn't the suspension the same on both?
this might explain a lot for me. I might need some more R&D. running 1000-3 fox on front of my 1000-5. Might need some new springs, front winch, glass windshield, 2 batteries! @joeymt33Preload starts measuring when the nut touches the spring when extended. Pretty sure the 3 and 5 have different length springs so you can't compare it from the top of the threads.
Thanks a lot for that!! I just got done putting my new fox 1000-3 shocks on my 1000-5!! it aint going to work out! Going back out to take them off!! didnt even come close to making it past the back yard test! I couldn't out run my dog without them rubbing. Thanks again for posting those im going to run them by joey he has helped me a ton! Hopefully Ill be able to order the right springs for me 1st try. Im also a real big guy so maybe I should go just a bit heavier than others?![]()
QA1 14HT250 QA1 High-Travel Coilover Springs | Summit Racing
Free Shipping - QA1 High-Travel Coilover Springs with qualifying orders of $109. Shop Coilover Springs at Summit Racing.www.summitracing.com
This spring for the front seems to be most commonly swapped to.
You could swap to the 5 seat front springs. Quiet a few members should have some they pulled off.Thanks a lot for that!! I just got done putting my new fox 1000-3 shocks on my 1000-5!! it aint going to work out! Going back out to take them off!! didnt even come close to making it past the back yard test! I couldn't out run my dog without them rubbing. Thanks again for posting those im going to run them by joey he has helped me a ton! Hopefully Ill be able to order the right springs for me 1st try. Im also a real big guy so maybe I should go just a bit heavier than others?
I think with me being a real big guy plus glass windshield, front batteries, winch, plus ride hard and fast I might want to upgrade to something heavier as well right?You could swap to the 5 seat front springs. Quiet a few members should have some they pulled off.
with this being said im not that good at this stuff so looking for as much help as I can get especially from you and joey!!I think with me being a real big guy plus glass windshield, front batteries, winch, plus ride hard and fast I might want to upgrade to something heavier as well right?
