P1000 Fox shock preload
BigOL3
BigOL3
2,997
8,921
Both shocks can give you the same lift. Just add or take away preload to the spring to get whatever ride height you want.
I thought so, but was not positive. Supposedly, per instructions, these should be set 18 1/2" between center of bolts for best performance. When that was done it lifted my front 2-3" and rear over 1". Pretty sure I could run true 29s, maybe 30s.
Reactions: BWAF
BBLASER
159
277
Phoenix
I adjusted my fronts to 1.5" of preload adjusted from black collar on top to top of spanner nut. I forgot to check initial height of vehicle before I did this and I am curious as to what kind of gain I achieved. Does anyone have measurements of theirs? I now measure 14" clearance to the front factory skid plate. When I measure my rear clearance to the factory skid, it is 12.75". I have some rear fox shocks on the way and am hoping to gain atleast an inch in the rear. Right now I do not like the way it sits. Oh yeah, factory 27" tires on 12" wheels
Reactions: TripleB and BWAF
TripleB
TripleB
20,241
177,748
Caryville, Tennessee
If u had it jacked up when u adjusted preload and then lowered it to the ground it will give u a false measurement. Ride it around the driveway and then measure. I had 12.5 but after I rode it was around 11".
TripleB
TripleB
20,241
177,748
So I kept adding preload until I got around 12.5" to the 1/2" skid plate cause that's what I had prior to adding shocks. I was just looking for a better ride not the lift.
BBLASER
159
277
Phoenix
Thanks man, exactly what I did and now I am @ 13" to factory skid. The ride is absolutely dialed in the front tho. The 1.5" of preload seems to be perfect. I took the daughter and went ripping thru some pretty rough stuff. The front end is amazing and now even more so highlights just how crappy the rear factory shocks are. haha Can't wait till next week for the rears to arrive.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Snuff, would you happen to know what spring rates come on the fox fronts for both the 3 and 5 seaters.
Here's some info some other members have found on the stock Fox shocks.
Spring Specs
1000-3 LE with Fox shocks
Front = 12.5" length, 2.50 diameter, 225# (033-08-032-2)
Rear = 15.25" length, 3.0 diameter, progressive 171/300# (033-09-000-2)
1000-5 fox shocks
Front = 14.5" length 2.5 diameter, progressive 252/350#
Rear = 15.5" Length 3.0 diameter, progressive 187/350#
From what I've saw the progressive upper coil binds or is very close to at ride height.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
1000-5 fox shocks
Huh.... may be a dumb question, but why would the 5 have longer front shocks? Isn't the suspension the same on both?
Reactions: dale5740 and BWAF
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
The specs are for the springs (I updated that). The shock lengths are the same.
dale5740
dale5740
886
417
mt airy md
Preload starts measuring when the nut touches the spring when extended. Pretty sure the 3 and 5 have different length springs so you can't compare it from the top of the threads.
this might explain a lot for me. I might need some more R&D. running 1000-3 fox on front of my 1000-5. Might need some new springs, front winch, glass windshield, 2 batteries! @joeymt33
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
This spring for the front seems to be most commonly swapped to.
dale5740
dale5740
886
417
mt airy md
Thanks a lot for that!! I just got done putting my new fox 1000-3 shocks on my 1000-5!! it aint going to work out! Going back out to take them off!! didnt even come close to making it past the back yard test! I couldn't out run my dog without them rubbing. Thanks again for posting those im going to run them by joey he has helped me a ton! Hopefully Ill be able to order the right springs for me 1st try. Im also a real big guy so maybe I should go just a bit heavier than others?
Reactions: BWAF
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
You could swap to the 5 seat front springs. Quiet a few members should have some they pulled off.
Reactions: BWAF
dale5740
dale5740
886
417
mt airy md
I think with me being a real big guy plus glass windshield, front batteries, winch, plus ride hard and fast I might want to upgrade to something heavier as well right?
Reactions: BWAF
dale5740
dale5740
886
417
mt airy md
with this being said im not that good at this stuff so looking for as much help as I can get especially from you and joey!!
dale5740
dale5740
886
417
mt airy md
Just from riding in the back yard for a couple min I can already see how the spring is rubbing the shock body. In the pic's below showing them mounted from driver side u can see how close the spring is to the shock body and rub marks as well! Rub marks are rear facing and plenty of spring clearance on spring towards front of machine. On the passangerside its just the opposite, has more spring clearance towards the rear of the machine and is tight and starting to rub in towards the front of the machine? Is this normal? Any thoughts?
IMG 0227
IMG 0232
IMG 0373
IMG 0374
s
