P1000 Fox shocks
Darvin
Indiana
So I tried researching on here and keep seeing how everybody says fox’s are better than stock. I have a 16 1000-5 with fox’s all the way around. My buddy just bought a new 21 and we went riding in az desert and his stock shocks are way better than mine. Mine just seem to be so stiff Even on the low setting. Beginning to wonder if my dials are messed up and it s stuck in high setting. Another test is if you push down on his machine it travels a ton. Do that to mine and barely moves Any help would be appreciated
TripleB
TripleB
19,339
171,479
Caryville, Tennessee
Is his 21 an LE with Fox shocks? Also does your 3 position adjustment knob have any resistance to it when you change the position?
Reactions: TimG and TxDoc
Gabbas
Gabbas
280
701
Humboldt, Iowa
I'll fix your problem. I'll trade you my stocks and $500. Your problem is solved.
Sent from my Pixel 4 using Tapatalk
Darvin
Indiana
His is the base model with stock shocks. There is a little resistance when I change them. If somebody services mine would there be a chance they put to much nitrogen in them ?
Reactions: TimG
Darvin
Indiana
I like your thinking lol. But would rather get mine dialed in.
Reactions: TimG
Elkhunter
Elkhunter
345
453
Minnesota
My LE with Fox shocks are way better than stock. A friend has a 1000-5 deluxe with stock shocks and after riding mine he wants to get them for his. Can definitely tell the difference between the softest setting and firm. I disconnected my sway bar for the type of riding I do. It has more body roll but not enough to convince me to put it back on.
Reactions: TxDoc
Hostile1
Alaska
If your shocks are 5yrs old then that is the reason! Take them to a shock builder and have them "rebuilt" , also if you want them stiffer or softer he can revalve them at the same time.
thashane
thashane
49
128
norCa
I would rather suspect you don't have any nitrogen left in your reservoirs and are bottoming. I second what Hostile1 said, and take them in for a rebuild.
Also- same tires and air pressure?
HondaTech
Unfortunately, dealers can't "rebuild" these. We only have access to exterior parts. Most don't even have the proper equipment to check for correct nitrogen pressure.
We have to send them to a Fox service provider to have anything done. Or if the machine is under warranty theyll just replace the shock itself.
We use GForce racing for our Talon race car shock service.
Reactions: TripleB
Hostile1
Alaska
Check your area for a atv/utv performance shop. It's a typical offering at most.
Vikes79
Vikes79
SKOL!
11,915
114,895
South Dakota
  2. Talon X4 LV
There’s a big difference in tires between the 12” base model tires and the higher models with 14” tires for the OP....kinda apples and oranges.
when I swapped my base model 12” tires for 14” take offs I noticed the ride was much more harsh right away.
Quite a few people run 12” rims for this very reason.
