P1000 Fox shocks
john790
357
1,093
Clinton ohio 44216
Does anyone know the difference between fox part #08Z70-HL4-FOO and fox part #51400-HL4-AG1ZA Thanks JOE
Reactions: Lady01
Scoop
Scoop
5,140
20,318
  3. Talon R LV
Someone can correct me if I'm wrong, but I believe the first part number is for a pair and the second part number is a single unit.
WagginTail
WagginTail
1,580
5,853
SC
The 1st # is the front shocks for a 1000-5. Not sure about the 2nd #
Reactions: Lady01
john790
357
1,093
Clinton ohio 44216
The reason i asked i have 4 different part #s and 4 different prices and i believe they are all for LEs so they should be foxes correct
Reactions: Lady01
Scoop
Scoop
5,140
20,318
  3. Talon R LV
Partzilla lists the 08Z70-HL4-FOO as fitting the Deluxe and base models, even though these don't come on them. I don't see LE or SE in the part listing, but assume they are the same (fronts only):
I believe the other P/N above is for a single shock vs the first P/N being a pair.
Reactions: Lady01
john790
357
1,093
Clinton ohio 44216
You are correct but #51400-hl4-b41za at 530 each.51400-hl4-ag1za at 372 each.51400hl4-f41 at 432 each i thank these are all le shocks.I understand different # for different years but if they are the same shock iam buying at 372 each.
