P500 Frame end caps
Q
Quetico
20
57
Hey gang, I bought the frame end caps from the Club store for my 2019 P5. I cannot figure out where they’d all go. I have 2 rectangles and one square that I don’t see a home for... anyone have better pics?
Also, are there no small square caps for the top tubes that exit near the exhaust? Seems incomplete without those covered...
Mudder
Mudder
NTC Ambassador of Walls
11,648
87,910
Just a thought, I used an air hose to blow Aviation anti-corrosion liquid inside frames. Don’t know if it makes a difference but did it.
66,853
Can u send pics and location of the one you need? Also maybe a measurment.
The kit just includes those for the 4 round tubes around the diff. 2 squares by the hitch, and 2, 1.5x3 for the main frame in front of the rear wheels.
The machine comes with the 1.5x3 for the frame on the front wheels.
And sometimes we throw in a extra square cap as they tend to go missing.
JCart
JCart
895
2,021
Kamloops, BC Canada.
Made my own from some UHMW and some hose. Great idea about spraying internal tubing with ant-rust coating...
cheers,
jrc
1589601177420
1589601266969
1589601343542
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
I bought the kit too for my P5 to spiffy it up before I sold it. You dont use all the caps, there is a few extra.
Jdh3
23
54
Ohio
I also bought the caps and they should arrive Friday. For rust proofing I used the stuff Honda has used on car frames Noxudol 700 panel wax. It is well rated and used for several of the service / corrosion repairs on Honda cars
Reactions: Mudder
P
pappyo
597
2,400
Have 2 club store kits.
Spray in side Frame with anti rust coating ( if only WD 40 ) used a small self tapping SS Screw to hold them in place.
During Winter Track season Spray allthe areas that collects ICE with WD40 ( helps when De- Iceing )
Reactions: Mudder
