P700 Front pinion seal
Conner
Conner
39
54
My front pinion seal squeaks doesn't leak any oil . It driving me nuts .
I put it on jacks and run in gear squeaking put my finger on driveshaft just light pressure and it stops . It way better in 4 wheel drive also . Tried wd40 think it made it worse. Any idea on a fix ?
2018 p2 250 miles
68,435
You could loosen up the diff and bump it causing it to reposition just slightly different. This will change the angle of the shaft that small fraction you need to stop it.
Reactions: Tflynn
Conner
Conner
39
54
That's a great idea, i will give it a try thinking it mite just work ! Should only take a few min to loosen up a try .
Conner
Conner
39
54
Well finally got time to loosen up dif and move it . Man works great no noise at all ! Thanks for the idea took all of 5min . Been very busy haven't had it out in a good month .
Thanks again !
Bassmf
Texas
Thanks again !
I am having the same issue what bolts did you loosen to adjust this lol it's driving me nuts
