Front spring spacers
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
I'm curious why you wouldn't want to go longer. Has anyone tried 1" or longer?
I have a ton of pipe (Stainless).
BTW: after reading several threads on this forum I removed my swaybar (Zip tied it out of the way). It was raining so I haven't tried it out.
Reactions: Tflynn
allgm1
allgm1
1,049
1,485
New Hampshire
I don't think you can go much longer because you can only compress the spring and spacer so much before it starts to cut into shock travel
Gator
Gator
2,489
10,470
Louisiana
I still wanna go 7/8" or 1".
Can you gain a little by adding similar spacers to the rear?
swsebek
swsebek
2,854
5,835
pa
I have run 1inch aluminum spacers for 1 year...At first I did front and back,Shortly after I removed the rears because 1inch was too much.The spacers gave me room to run my 28s,but the ride is no better......I will be getting fox shocks for the ride and the ground clearence
Reactions: Tflynn
Gator
Gator
2,489
10,470
Louisiana
In what way was 1" too much? I'm just trying to understand what's going to happen.
Reactions: dale5740
K
Ke6885
West ky
What size tire can you run after a spacer lift? Is it possible to clear 30s?
motorman18
439
277
Laurel, MS
Iv got 2 1/4 inch spacers on front with super ATVs lower arched a arm and I run 30s just fine they will hit every now and then in big ruts
