Talon Fuel mileage on Talon yet?
F
fartsalot
223
337
Near the Kansas Nascar race track
Hondabob, I wish I could say the same. My X was running 16.3 to a high of 17.4 mpg prior to today's run.
I am a volunteer with the ADGF and work four different mountain ranges checking water levels in the game tanks.
Today one of my shorter runs at 121.8 miles and I burned 8.4 gal of fuel, that figures out to 14.5 mpg. During the ride I never exceeded 50 mph but tried to maintain a good pace to beat the heat of the day. Luckily had a cloud cover and never exceeded 100 degrees on my run.
The run had a combination of open desert roads, rocky rough roads and some rock crawling at a slow pace.
I am at 887 miles and 42.1 hrs and was hoping as the miles increased, maybe it would break in and do better. But 14.5 mpg is not at all at what I was expecting.
Guess I need to come up to the high country with you where its cooler and see if that will help....
Maybe you and the Quadzmoto can put together a good ride for me....DRK
I will carry enough gas so I will be able to make it back, so you won't have to drag me back..
I sent you a PM
I can't see how anyone has bought a toy (specially the Talon).. and worried or was concerned about fuel mileage.. haha
Lol, that’s good. But some people probably just want to know how far they can go before running out of fuel and walking out. 🤷‍♂️
Reactions: DRKnight
hondablimp
hondablimp
MN
I get 15 mpg in the sand and close to 19 on hard pack, so I use 105 miles as my range to be safe , I do carry a 2 gal can with, sometimes more depending on where im riding. I refill at the pump so I thinks its pretty accurate.
Reactions: CID
hondabob
1,319
5,247
Prescott Valley, AZ
Didn't get a PM today, but good conditions should be in the low 20's. Sand, rock crawling, or lots of hard throttle can be 15 to 17 mpg. I'm usually going fast in 5th and 6th gear on my long 100 + mile rides and get around 22 mpg. It doesn't matter if I driving my 2019 or 202 Talon.
5,759
26,445
Stock tire sizes on both? If not, speedo correction or GPS mileage?
hondabob
1,319
5,247
Prescott Valley, AZ
Both with 30's and speedo mileage so its slightly better.
Reactions: CID
Hometeam
Hometeam
1,047
4,434
Normal, IL
I typically use 100 miles a day as my benchmark. I have yet to not be able to get at least 100 miles out of a tank of pure offroading with 30" tires. That is in the Tennessee area mostly. My driving style is skin peddle on the floor out of a corner and slow down for technical spots then back on the skinny peddle till the next obstacle. So I would say I am not the most fuel efficient rider out there....but fun/adrenaline factor is High! 🤪
  • Wow
Reactions: CID
hondablimp
hondablimp
MN
Mine has stock tires, speedo miles are within a few tenths of the Polaris command app after a ride. If that can be trusted.
