P1000 fuse block location
Jas sxs
Jas sxs
138
528
rankin county ms
I have a fuse block off of amazon positive on one end and neg on the other and fuses in between with a little clear cover
and I have been looking around the hood and cant see a place to mount it some i have seen are snorkeled and put a plate where the air intake was but mine if factory wit the air box where to put it so I can access the terminals ? pictures if possible
StewB
StewB
733
3,404
Hi. I have a 2021 P1KLE. If I did this again, I'd either not use the 30A circuit breaker or I'd shift it more towards the front.
As it is, the right-hand side connections to the fuse box are in a tight spot.
1660760880121
bumperm
bumperm
1,908
6,791
Gardnerville, NV
I used 1" square pieces of 3M Dual Lock tape. That allows you to stuff the fuse box where you can, and leave just enough lead on the wiring harness so you can move the fuse box to a more accessible spot for adding connectors etc.
Jas sxs
Jas sxs
138
528
rankin county ms
I made a couple of brackets out of some 3/16" aluminum. View attachment 349323
if I move my air breather that's a possibility do you have the air intake moved up high under the hood or a full snorkel I have thought about using the radiator hose mod to move it higher under the hood but but could not tell how much I would gain
bumperm
bumperm
1,908
6,791
Gardnerville, NV
I got rid of the stock breather and put in an oiled foam pre-filter. Freed up space and provides an easy way to prolong the life (and minimize service hassle) of the main filter:
20211009 212022
Reactions: WagginTail
Bow4life
Bow4life
129
540
Minnesota
I put mine right on top of the factory air intake cover. Just cut the "fins" off that were in the way. Then I made a plastic plate that the fuse block could sit on and mounted it in place. If I ever decide to snorkel it or add a longer air intake tube I'll just have to fab up a bracket for it. It was pretty convenient as it was right next to where I mounted my auxiliary battery.
20220818 124800
Jas sxs
Jas sxs
138
528
rankin county ms
that's a nice idea
that's what I am thinking of doing it right where it needs to b and easy access
Captain54
17
57
Arizona Territory
755D10A2 08B3 42CC 860C 7F33187A2CD7
Here’s yet another option for dual battery and fuse block placement. I just cut the clip off the air box to make room for the fuse block.
GROR
GROR
61
251
53
Castle Dale, Utah
https://www.amazon.com/Auxpower-Ele...ble-Waterproof/dp/B096K4PQDQ/?tag=sxsweb24-20 thinking about installing this 6 gang switch, anyone using this?
a_1_2_sspa?hvadid=73667436711425&hvbmt=be&hvdev=m&hvqmt=e&keywords=6+gang+switch+panel&qid=1660957272&sr=8-2-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExQ09aWFlKT1ROVDNCJmVuY3J5cHRlZElkPUEwMjg2NDc2M1NLWlBMNTY4Q0pUVCZlbmNyeXB0ZWRBZElkPUEwNDMyNDkyMjNTVlc1UElSMVZSUyZ3aWRnZXROYW1lPXNwX3Bob25lX3NlYXJjaF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
mrmagoolin
24
Oregon
https://www.amazon.com/Auxpower-Electronic-Automatic-Dimmable-Waterproof/dp/B096K4PQDQ/ref=mp_s_II'm thinking about installing this 6 gang switch, anyone using this?
Yes a lot of people use those. I have one. They work great for things that you are just turning on and off like interior lights, etc. but it does not work well if you want to put a fan under the seat and want to reverse it or to run a winch. They cost more, but make some that you can program the switchs to be on/off, momentary or strobe. The one you indicated appears to be on/off only.
