Getting water out of differential
Gator
Gator
The Most Unknown Member
2,488
10,460
Louisiana
Hey,
I have water in my gearbox. What's the best solution?
They won't completely drain.
PS: My first sentence read, "I have water in my rearend" That seemed like a dangerous statement on this forum.
Yankee
Yankee
280
723
Tennessee
Hey,
Drain it and fill it back with kerosene then drain that and refill
Reactions: Plumber32
Neohio
Neohio
Beast of the East
14,591
73,893
Painesville Ohio
Gear box or differential?
Front or rear?
jinx
jinx
565
528
I haven't serviced mine yet but I'd think you may be able to use a syringe (available at farm stores) with a small piece of tubing attached to get it out. I've used them on similar applications, just not the Honda at this point
Turkey baster with tubing may work as well
Reactions: swsebek
Mudwing
Mudwing
36,959
306,672
The Mud holes
Just out of curiosity, how did you get water in there?
Yankee
Yankee
280
723
Tennessee
Front or rear?
That's a trick I used back in my mud truck days when I got water in my differentials. Idk if the gear box has a drain plug but if it does it should work the same as the differentials
Hey,
I’m curious how this happens, I’ve never thought about submerging the diffs in water causing that problem. Now I want to go look at mine!!
Usually gets in through the vent lines. If you haven’t extended yours, do it. @Bayouownbeer sells a kit for it
Oh s*** ok, roger that. Thanks for that heads up, I’ll get with him. Wish I had that in place now as it would probably be quite handy this weekend right. :D
Reactions: nbomar
Gator
Gator
2,488
10,460
Louisiana
Sorry for the confusion. The water is in the differential and I'm sure it entered through the vent line.
This problem is on my Honda Foreman. It isn't snorkeled. It has a lot of miles in 12"-18" water.
I can fill it with motor oil and run it on the jacks the drain and repeat.
I can also try to suck as much of the milky oil out as I can.
Reactions: swsebek
272,200
B.U.D.S. training for SXS. Some people buy UTVs when they really need a johnboat.
208,726
I have a jet drive that will run in 4 inches of water, just need a jet drive on the back, that would really screw up your rear shock adjustments, HA!
