P1000 Got the Red one
Wow, that things a beast!
Reactions: pct
Boomboom907
596
620
Washington
How do those tires run? They look like 30s. I have intimidators and love everything about them other than how soft they are. I want a tire I can kick the snot out of and it will still hold up.
Please update after a few hundred miles if there is any chipping in your tread.
Guito
Guito
91
142
Seminary MS
Guys... I hear we got a 1,000 acres opening up for the first time around Hattiesburg. I got a friend that's taking a small group down this weekend.
Do you know where or what it's called?
Reactions: BigOL3
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Went between these and the intimidators, some had mentioned lugs not holding up to rocks and these are 8 ply so that's what I did. Maybe I can soon get some time in on them.
Boomboom907
596
620
Washington
Good call. I imagine they will be close in performance. I'm excited to know how they hold up
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Just a little bend and longer bolts for stick stoppers to work on a-arms
IMG 1008
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Mostly would have said skids were for you rock guys, but I was lucky that a stick just busted the push pins loose.
IMG 1486
A branch got lodged between the gas tank and the floor on my 700 and the right side tires were off the ground that's when I started my search. I was on flat marshy ground.
69,903
Throttle cable froze up
I just went through that. I got a syringe and injected iso heat in the cable. Every time I thought it was fixed I would park it outside and it would freeze up. I injected approximately 5 syringes full throughout that line to get it worry free again
Reactions: chadbo
BigOL3
BigOL3
2,997
8,920
Where/what is this place around Hattiesburg, you speak of? Near Rattlesnake Bay/Camp Shelby?
Disregard. Saw it in a later post.
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Gonna try to plastic dip rattle can front fender before 2nd battery install
B150B278 72FD 4120 80AB EAE1CBA33B45
Reactions: Eltobgi
