P500 Ground force atv system
Yellowbeast
Yellowbeast
64
111
Pennsylvania
Next year I’m planning on getting power steering and one of these ground force systems. I can get the unit with a set of forks and bucket and suspension lock for around $2000. I will use it to move stone and dirt around so I don’t have to do so much shoveling lol. Does anyone have this system or any bucket like this? If so how do you like it. Also do u think running a winch power steering and head lights at one time is to much on the stock battery?
Thanks
1022E5D5 07E5 479D 8B17 15AFB97B6D07
NTC/TAP Transition Member
11,854
90,259
Never saw that before. I made a bucket for an atv plow, puts a lot of weight on front end and steering. Stiffen up the shock setting and maybe add some rear counter weight. Consider a dash volt meter to monitor battery voltage, just ordered LED digital one with USB ports. Power steering under full load rated at 220 watts. Think about running a separate circuit with a resettable Bussman breaker to protect a 4 or 6 gauge wire to supply whatever the combined load turns out to be.
D1510CAC A99B 4FB4 B5DA E541C8461859 20F68C7F 7330 494E A0C4 9E3CB78BF225
211,612
Thanks
They've been around for a long time, there called tractors. HA!
11,854
90,259
Looked at some YouTube videos. Guess you will be the tester for the P500.
Reactions: rtn001 and Mudwing
U
uconn411
160
255
CT
I have a Warn 60” provantage plow with the bucket kit for it. Works decent, though if you are going to convert from plow blade to bucket it will take you about an hour the 1st time. I have Walker Evans adjustable suspension all around with 200lb springs. Your not going to dig into the earth like a front loader but for moving around soil or mulch works great.
53e4ca623bafa8d49f3c3c1b8ab0484dFff9818baf86ff952665f1f9e316f4a2
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
If I put a splitter on my P5 for better handling at high speed, do you think I will also need to install power steering, I think the downforce may make the steering heavy.
Reactions: rtn001
Yellowbeast
Yellowbeast
64
111
Pennsylvania
How has the bucket been holding up for you? And is the dump leaver hard to pull? Thinking about getting the swisher atv bucket instead. That way I only need one winch and I can adapt the bucket to my existing plow mount instead of needing to switch mounts.
View attachment 144450View attachment 144451
