P1000 Gun Mounts
TexasHeat
TexasHeat
30
25
Texas
I have both overhead and floor mounted. Problem for me is my head hits the overhead gun racks with rifles in them so I had to take them out. The floor mounted/detachable is a much better option for me. The biggest issue is the floor is just a plastic piece and when you put your guns in the holder it will bend and distort the plastic. To rectify the issue I pulled the plastic center piece out and added on the bottom side an aluminum plate 1/4 inch thick and bolted thru mounting plate, plastic floor board and they The aluminum plate. This helped stiffen and also steady the guns when attached.
Reactions: X4Dice
Hondoman
Hondoman
727
1,697
Texas
That's the same one I have. Works ok. The only issue is the front holder is a little close to the mirror. Just have to be easy putting the gun in.
Griff
True, same here.
Hondoman
Hondoman
727
1,697
Texas
I have both overhead and floor mounted. Problem for me is my head hits the overhead gun racks with rifles in them so I had to take them out. The floor mounted/detachable is a much better option for me. The biggest issue is the floor is just a plastic piece and when you put your guns in the holder it will bend and distort the plastic. To rectify the issue I pulled the plastic center piece out and added on the bottom side an aluminum plate 1/4 inch thick and bolted thru mounting plate, plastic floor board and they The aluminum plate. This helped stiffen and also the bottom mounting plate of the
I havent hit my head (yet) and I'm 6'3". When hunting, I almost always have two and sometimes three in the front seat. I couldn't find a floor mount that didnt take up too much floor space.
The overhead mount was a compromise in accessibility/out of the passengers way for me.
Hondoman
Hondoman
727
1,697
Texas
Honda1000-5
Honda1000-5
216
342
New Brunswick Canada
What are people using for rifle mounts in your 1000? I would like a floor mount but roof seems nice too.
I use Kolpin's In-Cab Vertical Floor Mounted 2-Gun Universal Gun Rack Model#20073. I bird hunt and it holds 2 shotguns at the ready. It is solidly built adjustable. I mounted it on the floor in front of the middle seat.
Reactions: BWAF
O
oldfortyfive
607
1,383
Illinois
I really like Cabela's double gun case. One gun goes in from each side. They stay clean, well protected and are easy to unzip and go.
Honda1000-5
Honda1000-5
216
342
Here in Colorado we used to be able to open carry on our ATV's, but now, anytime you have your rifle located on your ATV and your driving from point A to point B, your rifle must be in a gun case and unloaded. How many other states have this law?
We have that regulation here in New Brunswick,Canada but a Gun Sock meets the letter of the law and I use that with my guns in Kolpins In-Cab gun rack---gun can be ready in a few seconds.
Reactions: BWAF
Honda1000-5
Honda1000-5
216
342
20190223 074820
Above are photos of my In-Cab gun rack.
Reactions: X4Dice
