popeye
popeye
3,273
14,641
kapowsin, Wa
43b29461736bd36439546b23c0317479
41,771
Was it Monday? o_O
It was. Real head scratcher in a chevy Express van. What seems like a lean hesitation. I'd swear the MAF is bad, but we tried a "known good one". Fuel pressure is good. Cats aren't plugged. Everything seems good. Seriously think I'm going pull a plug and see if someone swapped In a 5.3 with the 4.8 software...but fuel trims don't support that.
I lost today. I don't like loosing.:mad:
319,857
You won’t lose tomorrow.
Russ989
Russ989
22,569
146,535
Wow, must have been a rough Monday for everyone...?
Well my Monday was going good until I got off work and went to feed the cows. Apparently the side door didn’t get latched and they came in and ransacked the barn. It was a s***ty situation to say the least. I got them all back out into the feed lot and headed for the house. We spent 4 hours this evening cleaning it up, still have quite a bit left to do.
364B03CF FD59 48B8 A646 FA33975D01E4
4972B60A 389D 49A8 97B6 3BB8B54AD4D0
5E7BABB7 43BC 4B73 9AA8 DFD419E1465E
Mopower58
Mopower58
CST is the Best!
70,140
644,363
Crystal Springs,Ms.
Whenever we had hesitations, particularly when cold, we cleaned the injectors, 4.9 (300 cid's) were particularly bad. 2.3's were bad about carbon on the intake valves. The carbon would absorb the fuel charge and result in a hesitation.
Mopower58
Mopower58
CST is the Best!
70,140
644,363
Crystal Springs,Ms.
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
This is interesting for all you NW guys
Two Floods recorded in the Bible that completely covered the Earth, Genesis chapter 1: 2-10 this is the first flood, Genesis chapter 7: 17-24 and chapter 8: 1-5 this is the second flood,,, in secular History China has some of the oldest recorded history in the world, the first Emperors commissioned a man by the name Kun to drain the waters off the land Kun was unsuccessful but His Son Yu figured out a way to drain the water off the land it took Him 9 years to drain the water to the ocean, because of this He became an Emperor and began China's first Dynasty, this took place only a little more than 100 years after approximately 2250 B.C. the second flood Noah's flood this water that lay in low areas from the flood ,,,,, within approximately 2250 years 2 earth covering floods took place that formed the Earth as We enjoy it today,,,
