Ham radio questions please help
Dasmoeturhead
With a quad radio, you either need an adjustable tunable antenna that can tune all 4 bands (pretty darn spendy ) or at least 2 antennas for say 2 meter, and 10 meters. It's a pita, but that's the options. Bear in mind cb 11 meters, and 10 meter ham frequencies depend a lot on conditions, where 2 meter really doesn't.
Dasmoeturhead
Here's what's in my p1k. Note, this is my cb antenna, not the 2meter. But I can mount the 2meter antenna on that steel bracket, and it holds tight
20160729 121828
20160729 121840
20160729 121849
20160729 121925
20160729 121828
320,749
Reactions: Biteme
320,749
Not hard at all.
Ok I ordered the two handhelds. I found those I showed you for 64 so that's awesome. Still looking for a reasonable radio for the pioneer. Could you please walk me through a little when the get here?
Reactions: Biteme
fishin2Dmax
fishin2Dmax
186
32
Ok so I'm dumb in ham radio. Used cb's some but looking max distance/value and know nothing on this matter. From what I'm seeing on line CB doesn't make sense for the price. Looking for probably 50w base unit to install inside the pioneer and a good handheld 8w. Looking at baofeng so far the reviews for the price look great. We have a 200$ cap as my wife received a gift card late for her bday and it's time to have better communications. Please help
As a licensed Ham radio operator for the last 35 years, I can't believe how easy it is today to get a Ham Radio Technician license. Back in the day we had to learn a lot of electronic theory and morse code. While there is some study involved, most people with no electronic background (including my wife) can pass the test with about 8 hours of study and test practice. Each person operating a radio in the Ham radio bands MUST have a license! Ham's are very sensitive to non-licensed operators and the fines and / or imprisonment is very stiff for improper operation.
I have many different ham radios and one of the very best I have found for distance (and low lost) is the BeoFeng UV-82HP. This is a high power 8 Watt hand held for $60. The Beofeng / "chinese" radios are very hard to beat given their very low cost ($15 to $60). The Chinese radios on Amazon.com (BeoFeng and others) can be programmed to almost any VHF or UHF frequency. You will need to order a programming cable and download a program for your specific radio to program the frequencies you wish to use.
Many people that don't have Ham radio licenses purchase the low cost Chinese radios and program them to use the standard the GRMS / FRS (public use frequencies) like the Motorola talk about radios and store bought walkie talkies use. While these frequencies are legal to use, the Chinese radios are technically not legal to use on GRMS/ FRS frequencies; they have removable antennas (possible use a higher gain antenna) and may also have much higher power than is allowed.
I use my UV-82 HP (on ham radio frequencies) in my Pioneer. I have a holder for it under the dash with a remote antenna and a speaker mic. Works great and I also take it with me once I get to my destination by simply unplugging the external antenna and putting the rubber duck antenna back on - for hunting/ fishing. The UV 82's or UV 5's are GREAT low cost hand held radios (they also have FM radio and a built in flashlight).
320,749
B38ffbdaf76bf56a857237941537a83a i just got two of these as a set for right around that same money. Spent a little time as I always do before a purchase and beofeng keeps coming up everywhere I hate being a follower but with reviews it hard not to. Can't believe how reasonable these have become. We need To have communication but after a couple mishaps it needs to be trustworthy. I absolutely plan on getting a license and will be studying along with a few others in our group. Very excited
Sent from iPhone
320,749
I have never used the programming cable. I just enter the info through the keypad.
Really I'm in good hands then! I'll be bugging you shortly. Still looking for a 50w-up base unit for the pioneer and will be getting extra batteries as you suggested.
Sent from iPhone
Reactions: Biteme
Dasmoeturhead
Better hit me up before Beer 30. Haha
Sent from iPhone
Reactions: Biteme
Dasmoeturhead
What type of holder do you have to hold your HT in?
320,749
@Dasmoeturhead which diamond antenna?
Sent from iPhone
Reactions: Biteme
Dasmoeturhead
^^^^^ that depends on how and where you are going to attach it. Magnetic base, or a straight type shaft.
Reactions: Biteme
Dasmoeturhead
I think a Firestick non ground plane 2 meter antenna would work great. There only 2 ft high, and can be mounted pretty much anywhere you can think of. I would also suggest a quick disconnect so you can take it on and off quickly.
FLAT RATE SHIPPING
Based on the total order
Up to $50.00 ........ $ 6.95
$50.01 to $100 ..... $ 8.95
$100.01 to $500.... $ 9.95
$500.01 to $1000.. $14.95
For USA customers
(except: AK/HI/PR)
Insurance included.
Amateur Mobile Antennas
Chameleon V2L Vertical 80m-70cm
Comet B-10 & B-10NMO 2M/440 Antennas
C757 & C757NMO 2M/440 Antennas
C767 & C767NMO 2M/440 Antennas
CA-2x4SR 2M/440 Antenna
CSB-750A, CSB-770A & CSB-790A 2M/440 Antennas
M24M, M24S & M24SJ 2M/440 Antenna
SBB- 1 & SBB- 1NMO 2M/440 Antennas
SBB- 2 & SBB- 2NMO 2M/440 Antennas
SBB- 5 & SBB- 5NMO 2M/440 Antennas
SBB- 7 & SBB- 7NMO 2M/440 Antennas
SBB-14 6M/2M/440 Antenna
SBB-15 6M/2M/440 Antennas
SBB-25 & SBB-25NMO 2M Antennas
SBB-224 & SBB-224NMO 2M/220/440 Antennas
SS460SB & SS460SBNMO 2M/440 Antennas
SS680SB & SS680SBNMO 2M/440 Antennas
UHV-4 QuadBand Antenna
UHV-6 MultiBand Antenna
Duplexers & Triplexers
Mobile Mounts
COMPACtenna 2m/220/440 144-148/219-225/420-450 MHz Antenna
28-450 28-29.7/50-54/144-148/219-225/420-450 MHz Antenna
V.U.7/800 (V.U.7/800S) 144-164/380-520/696-870 MHz Antenna
UHF Veh 400-500 MHz Antenna
220 Veh 219-225 MHz Antenna
6M Veh 50-54 MHz Antenna
10M/CB Veh 27-30 MHz Antenna
Diamond AZ504SP 2M/440 Antenna
AZ504FXH 2M/440 Antenna
CR320A 2M/220/440 Antenna
CR627B & CR627BNMO 6M/2M/440 Antennas
CR8900A 10M/6M/2M/440 Antenna
D-220 Mini Discone 100-1600 MHz
HF CL series 6M & HF Monoband Antennas
HF6FX 6M Antenna
HV7A 10M/6M/2M/440/+ Antenna
MR73SA 2M/440 HT Antenna
MR75S 2M/440 HT Antenna
MR77 & MR77SMA 2M/440 Antenna
NR22L 2M Antenna
NR72BNMO 2M/440 Antenna
NR73BNMO 2M/440 Antenna
NR770HA, NR770HB & NR770HNMO 2M/440 Antennas
NR124N, NR124NMO 1.2 GHz Antenna
NR2000NA 2M/440/1.2 GHz Antenna
SD330 HF Antenna
SG7000 2M/440 Antenna
SG7500A 2M/440 Antenna
SG7900A 2M/440 Antenna
Mobile Mounts
Hustler CG-144 2M Antenna
CGT-144 2M Trunk Mount Antenna
CGT-220 220 Trunk Mount Antenna
MX-2/2B 2M Magnet Mount Antennas
MX-270 2M/440 Magnet Mount Antenna
RX-2 2M Magnet Mount Antenna
SF-2 2M Antenna
SF-220 220 Antenna
HF Mobile Antennas & Supplies
Icom AH740 HF Antenna
Jetstream Mobile Mounts
Larsen NMO Series VHF/UHF Mobile Antennas
Kulglass VHF/UHF Mobile Antennas
Mobile Mounts
Maldol EX-107B 2M/440 Antenna
Mobile Mounts
MFJ MFJ-1722/1722S 2M/440 Antenna
Mobile Mounts
MP Antenna M-400 440 Antenna
Super-M Classic Mobile Mobile Antenna 25-1300 MHz
Super-M Ultra Mobile Mobile Antenna 25-6000 MHz
Opek HVT-400B HF/VHF Mobile Antenna
HVT-600 HF/VHF Mobile Antenna
VUG-144 2M Thru-The-Glass Antenna
VUG-270 2M/440 Thru-The-Glass Antenna
Mobile Mounts
Procomm CD144M 2 Meter Magnet Mount Antennas
Mobile Mounts
Shark S-F / S-FM HF Mobile Stick Antennas
Surmen MAX1B/BNMO 2M/440 Antennas
UT-108SMAF/SMAM 2M/440 Antennas SMA-J/SMA
Mobile Mounts
Workman Mobile Mounts
Yaesu ATAS-120 HF/VHF/UHF Antenna
Please also see: Amateur Base Antennas
HT/Portable Antennas
Discontinued Mobile Antennas
Please note that antennas are not returnable.
Copyright 2000-2016, Universal Radio, Inc.
Reactions: Biteme
Dasmoeturhead
Sorry about all that info on antennas. I'm just going to stop using my phone to try and copy from a website. Not sure what I'm doing wrong. Anyway look up that Firestick. It will work good on both your p1, and MH.
