P1000 Hard mid panel install
brennen
brennen
47
115
michigan
Just got the hard mid panel and I can not get the two clamps done. I have my Honda hard roof lifted out the way. Looking for some pointer before I just return it for the soft mid panel. Is there somewhere that needs trimmed. Not sure what I’m doing wrong
115,286
Did u download the instructions, or just winging it? Not trying to diminish you here.
Reactions: Smitty335 and EMAW
115,286
I have the instructions. It hits pretty hard in the top corners of each side where the roof frame has the angle piece attached
Good, sometimes the distructions have a trick hidden lol.
my experience with the clamps on the windows And other accessories is that u have to loosen up the lowers to almost a disconnect, get the uppers on and slightly threaded then work your way around till there all tight. Bottom line is all those OEM accessories are a very tight fit. Just need to improvise, adapt and overcome!
russknight
russknight
1,910
7,509
Perry Florida
Do you have all three of the tabs at the bottom inserted behind the metal framing?
brennen
brennen
47
115
michigan
@brennen how did it go, any luck?
It’s installed. If you can tell from the picture where it isn’t wide enough to cover the outside. These are the corners I wasn’t able to use the rubber seal given either. The opposite side is just barely covering the corner. Also wasn’t able to clip on of the roof mounts back up.
but for the most part it’s Installed
8DE26A3E 906D 4385 8940 449FED5A026B
russknight
russknight
1,910
7,509
Perry Florida
Can't tell much from that photo.
271,861
If the clamps are upside down in throws it off by about 1/2" I ran a hard mid panel for 5 years took it in and out every summer / winter. I always just put the center piece in, then installed the two triangle wings on the sides after the main part was set, since it only took 6 fender clips on each side to secure them.
brennen
brennen
47
115
michigan
Did you need to do anything with your roof every time you installed and took it out?
