Well I finally got all my kinks worked out from water being in the engine (I had no issues with motor when water got in it. I was having clutch slippage and some electrical connectors got wet which was causing more issues than anything) and am now having some engine rattle.
The noise only seems to happen between 3k and 4k rmps. The noise is not as noticeable until you are moving, while parked and reeving the motor between the 3k-4k rmps there is a slight noise but nothing like while driving. I wouldn't say that the motor is knocking it is more like a chatter/rattle and seems to be up under the seat not towards the rear of the sxs.
I guess my questions would be could this be something in the motor or has there been some washer/bolts that have came loose on other sxs that has caused this noise.
I will say and as much as I hate saying it I did use sea foam (which was recommended by a friend that is knowledgeable with mechanics and has used this product) in fresh gas through the fuel tank as per directions. I am not formilar with this product but was told that he had used it in his maverick that had been swamped and it would pull some of the moisture that was left in the fuel tank/system and would do a little bit of internal cleaning. With this being said the noise started after adding this into the fuel but could just be a coincidence.
I do have the extended warranty on my machine and might have to take it in to have them take a look but would rather not due to them having the machine for a length of time and the other by voiding my warranty if there is still signs of water.
