P1000 Having some engine rattle
Mario17623
11
Dallas
Bent rod for anybody interested.
This guy opted to just replace the 1 rod only, I believe it was the rear cylinder.
We installed a new rod and piston and haven't seen him back yet. Apparently he'd gotten it pretty cheap at auction.
These are both side, they seem to be fine unless I take them out completely and check
1976EC9C 7C84 443B 84B7 B93CD81E06A8 025C17BE D3F9 4540 81D8 DEE48DFD0A21
Mario17623
11
Dallas
I took off oil pan and I see a lot of metal shavings some thin metal and some look like thin wire
HondaTech
Definitely looks like some bearing material or maybe even piston pieces.
Is any of it magnetic.
Mario17623
11
Dallas
Well it's not piston then, I would think if it was bearing, you'd get a worse noise.
Could be a gear then maybe?
Idk I might start taking it completely apart this weekend to see what is wrong or what looks wore down
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Best bet is to pull the motor out and go through it.
russknight
russknight
1,910
7,511
Perry Florida
You couldn't just take a big hammer and straighten it out????
Mario17623
11
Dallas
Well I think I found the issue, I moved the rod and one was moving more than the other one. There was no bearing inside and the bearing inserts have a lot wear
E807241B 5B24 41BB 9ED0 9A472D9BC201 B72F2B70 7AC7 4519 A29E C5A03FD0EBBB
Reactions: russknight
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
View attachment 139918 View attachment 139919
Going to need a new crank and rod. Defiantly pull the motor and fully disassemble, check and clean. There had to be an oil pressure problem at some point. Need to check the pump gears, pickup, etc... Also with no bearing, the oil pressure throughout the motor would have been really low so there is probably wear in other areas from that.
