saw this tonight - not sure what it will consist of but it’ll let you run 32” tires
This is the first kit they are doing. OEM width setup. The next kit will be long travel. Been messaging them on Facebook.
Long travel with normal length shock? Just got 814s but I'd love more travel
Ouch!Their long travel kits for the YXZ and RZR starts at about $8k.... Awesome stuff though.
Front talon shafts will fit an LE only, if they fit any Pioneer. Rears are up in the air with it being a locked diff vs open on Pioneer.Long travel is something I would love to do on my P1000. Fabbing longer arms is very doable. Longer tie rods are very easy.
Longer axle shafts?
Found several places that can do custom length shafts.
Talon parts?? Spent some time at the dealer today and took some pics. I swear I could graft in Talon factory arms for the front. Would require some new frame mounts.
Will the Talon inner CV fit the P1000? I know the Talon has the intelligent 4wd, but does that change the CV.
The rear would be totally custom arms.
Any idea what the difference is for LE/Talon vs normal? Was wondering if the LE would work in a normal Pioneer, but a normal not in an LE due to something like a tone ring for the LE's I4WD systemFront talon shafts will fit an LE only, if they fit any Pioneer. Rears are up in the air with it being a locked diff vs open on Pioneer.
I4wd uses a tone wheel on the cv shaft.Any idea what the difference is for LE/Talon vs normal? Was wondering if the LE would work in a normal Pioneer, but a normal not in an LE due to something like a tone ring for the LE's I4WD system
Just wondering if the LE with the tone ring will fit in a standard. Or if the tone ring makes it so dimensionally different, it will not. If it will, we could possibly use the Talon in a non LE Pioneer, it would just have an unused tone ring.I4wd uses a tone wheel on the cv shaft.
Much like an abs sensor in automotive. That is how it senses slip and applies brake.
I don't believe a LE axle will fit in a standard Pioneer. Different seal diameter etc.Just wondering if the LE with the tone ring will fit in a standard. Or if the tone ring makes it so dimensionally different, it will not. If it will, we could possibly use the Talon in a non LE Pioneer, it would just have an unused tone ring.
Anyone heard an update? Not real sure why I’m asking because it’s going to be hard to justify the purchase. Just for comparison, the Kawi teryx kit would be pretty much the same as the pioneer and it’s $5000.
BUT, I could sell the Elka stage 3, front and rear a-arms, and axles to offset the cost.
Dang it! Why did they have to start making this?
