P700 Heat shield
Max718
Max718
246
366
Mississippi
I am in the process of checking my valve clearance on my 700-4 . I have never checked them can't hear them making any noise but think it is a good idea to do so. Started taking it apart today and found this piece of foil laying on exhaust pipe .I think it's a heat shield. Any ideas on what to use to replace it with
Mudwing
Mudwing
36,959
306,672
The Mud holes
I found that same piece of foil on mine laying on the ground after washing her. It looks like it goes under the plastic in the center of the seatbelts. I did not replace but noticed a little more heat coming out. Interested in the replacement also.
swsebek
swsebek
2,854
5,835
pa
I think it goes above the header below the middle of the plastic under the seat.
Max718
Max718
246
366
Mississippi
You can see where it was glued to the plastic under the seat might check at local auto parts store to see if they have any type of heat shield material
swsebek
swsebek
2,854
5,835
pa
IMG 4729
Ok I was wrong. It goes towards the front and its verticals behind the plastic behind your calves. It's just foil tape you use on furnace pipes..
IMG 4730
I thought it went there.Im getting ready to do an auxiliary battery install and noticed.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I'll have to check mine and make sure it's still there..Thanks for the info
Mudwing
Mudwing
36,959
306,672
The Mud holes
The big question here, is this piece of foil necessary? It looks so chintzy.
Reactions: Deluxe700
tjoreo
tjoreo
1,025
1,975
Southern Idaho
Mines been off for a couple of years or 3000 miles ago. The plastic in the middle does get a little warm on the back of your legs if your in the middle, but other then that, it hasn't melted anything. I thought about installing a piece of offset aluminum shield, kind of like a heat sink, but I haven't got around to it. Maybe in a couple of more years.
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
My grandson burned the back of his leg. Nothing serious but enough that he cried. I plan to add an insulating foil like @swsebek mentioned.
swsebek
swsebek
2,854
5,835
pa
Its hot for my son or I wouldn't worry about it too. Can't have the little man sad:)
Max718
Max718
246
366
Mississippi
Went on a 4 mile ride this afternoon when we got home I took the seat out and checked to see how hot the plastic cover under the seat was . Almost to hot to touch got to get something to put back under there . It may have been like that before but now I will think about it every time we ride
Reactions: swsebek and Mudwing
K
kswaterfowler
946
3,537
Kansas
How did itwork? My plastic gets miserably hot. So hot you dont want to touch it.
Reactions: Mudwing
