P1000 Heater Installed-- How to Burp
red1329
red1329
109
471
central il
After doing my heater and having these issues what i did was
1 ditch the shut off by pass loop. now the oil cooler line goes straight to my heater core and from the heater core to the oil cooler.. i use to have some tees and shut off valves for a winter/summer mode.
2 i bought a little 5/8 water pump from amazon for 20$ and wired it to my blower motor power. when you turn the blower motor on the pump turn on. this pump helped with the air pockets. if forced the water through fast enough to burp the heater.. i get a lot more heat out of the core now. i also had to insulate the duct work from the core to the cab. that also makes a hug difference
Y
Yakman
128
315
WA
Took your suggestion to run heater inlet hose to oil cooler but I put the outlet hose to the water pump where the oil cooler had been connected. Works great! To clear the air pockets (burp it) I used the method in the instructions for my SuperATV heater that was much easier (see attachment). This forces all the air to the radiator and it burps itself. Pretty crafty way they came up with.
Capture1
Reactions: red1329 and Lady01
