Hello from trailrider1205
trailrider1205
10
7
Edgerton, ks
Hello, I'm trailrider1205
So I'm in the market for an UTV. My 4 wheeler was stolen that I used to do so many different things with around my property. From fixing fence to spraying pastures. After using my dad's UTV this is what I will be buying. I'm pretty sure I have narrowed it down to the Honda Pioneer 1000 or 700 and the Can Am Defender.
Here is a little info about me to begin with!
Honda SxS ownership : No, but I am looking to buy
I have owned, or currently own the following:
My off-road experience level is: Novice
My favorite place to ride is: my property
Reactions: Miss_Oak
Bigtee
Bigtee
556
1,213
Grayson, KY
Welcome from Kentucky
7,182
27,656
Welcome from Texas
I would sag that if you are looking for mainly a utility vehicle for the property i would say the 700 fits that job the best. I had a 700-4 and had 0 issue's and worked great for farm and ranch work.
trailrider1205
10
7
Edgerton, ks
Is the 1000 geared more towards trails and not for work?
I had the 700 and moved up to the 1000, it probably sees 80% utility use time wise.
You can't creep along at 1mph with the 1000 if you do you are just slipping the clutch. 3-4 mph and it's locked up.
The 700 is an automotive style automatic transmission with a torque converter. It can creep at 1mph all day long.
If you can lock the clutch up on the 1000 you're good.
I use my 1000 to poison our driveway, trails, and fence line as well as various other things around here.
The 1000 has much more power, better suspension, high/low range, "turf mode", I upgraded because it was more suited to what I needed/wanted.
Reactions: Tigermark
trailrider1205
10
7
Edgerton, ks
Thank you. With the 4 wheeler I always sprayed around 5mph. I don't think I ever creeped it along on any of the tasks I used it for.
Reactions: ohanacreek
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Welcome to the Club!!
swsebek
swsebek
2,854
5,829
pa
