HELP Please!
HondaTech
Give me a few, my good laptop is a work. I'll drag the old dinosaur out and see if I can come up with anything.
Does appear to be code 52 in the video
Edit: OK, so for 2019 and up models the code list is different.
Code 52 is Neutral switch stuck OFF.
Look at the left side of the engine inside the rear output shaft area the neutral switch should be there. Its just a single bullet connector that snaps onto the switch. Its most likely unplugged. If thats not the case let me know, we'll go from there. But since it immediately shows up when turning the key on its either unplugged or a bad sensor(which is unlikely).
HondaTech
Thank you for looking into it !
I edited my previous post, take a look at the Neutral switch.
Picture for reference
20201225 161402
906UP
906UP
14,692
139,587
da Yoop
You my friend are AWSOME!!! I got it. The connector was spread open. Thank you so much everyone for the help!!! I will do anything I can to help return the favor.
Yay..... I take it that it fixed the issue? Thanks @HondaTech for helping the guy out on Xmas day.
