Hi All,
I've been reading on HondaSXS for awhile now, but first time post here.
Around 2 weeks ago I purchased a new 2022 1000-5 Pioneer, and I'm starting to install some accessories, starting with the new Honda Heater. The instructions start by having you remove a fairly large list of parts from the Pioneer, which I've completed except for the last item on the list, which is the Heat Shield.
I've removed what I thought was the heat shield, but it does not match the photo of the Heat Shield in the installation instructions for the Heater. This Heat Shield requires drilling/cutting templates be attached to it, but for the life of me can't find a part that matches the pic. Is anyone familiar with this part, or can tell me exactly where it is located? Here are some pics of the machine and work in progress. I posted a pic of what I think is the Heat Shield, and what its supposed to look like according to the install instructions. The shield I removed has a plastic insert connected to it, and that is labeled "Heat Shield Cover", so I can't be too far off I wouldn't think...
Machine nearly disassembled and ready for heater install
This is where I removed what I thought was the correct Heat Shield (originally covered the exhaust ports)
This is the heat shield I removed that doesn't match the install instruction picture.
This is what the instructions say to remove and modify, but this does not look like my heat shield.
The machine is a 2022 and the instructions/Heater kit are the 2022 version.
Thanks anyone who can help!
