Koda
I can't stand exposed wiring and was thinking about running all my overhead wiring through the Rollcage. Looking for pros and cons of doing this.
Except were the cage bolts togetherIf you drill a hole in the top and bottom and use a wiring fishing tape you should be able to get them through
I used some black split loom, just sized it just big enough for the wires being ran. Hiding it where i could. I honestly think only some one that has a rig that has wired in things might be the only ones who would see it. But still looks pretty professional. And its cheap on amazon or ebay.
Rear ROPS pretty easy just a little wire loop at bottom where it bolts to the frame, mid not really possible, front with a windshield or partial lower hole it'll be hidden where it comes from dash and into cage and upper will be into roof good. If you do I'd expanding foam inside at the hole to get strength back.
I did run everything through tubes in the bars on our last pk1 and it was good but made upgrades hard and overall pita.
Rear is much more doable.The rear and mid section is where I wanted to work on
