P1000 Hold down for 2nd battery??
E
elarson6772
34
109
Saginaw, Michigan
  1. Looking to buy
I’m ordering everything for the addition of the second battery and all the typical other additions that go with it when I take delivery of my 1000-6 next week. The only thing I haven’t found referenced is what everyone is using for a hold down for the new second battery?
Thanks in advance!
Eric
Reactions: TxDoc and Coeus
Coeus
Coeus
Major General
67,149
648,727
Signal Mountain, TN
  2. Talon R4 LV
Thanks in advance!
Eric
I used some old foam pieces I had laying around… nothing permanent… has held up so far…
115,286
Thanks in advance!
Eric
Welcome fellow Michigander and suffer from the clutches of Big Gretch!
I used a metal band strap.
There are a few threads up top in the search with Ideas for this as well or folks build threads.
Dont Forget to post up Pics when u get your rig. Its Rule #4 here POIDH
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
Nothing. It just sitting in the hole. It doesn't move.
Reactions: ChadD and brettc
Scoop
Scoop
5,130
20,277
  3. Talon R LV
Another welcome from Michigan. I've posted mine three times on the forums (two times too many, I suppose):
someguy1313
someguy1313
236
514
SouthEast
NorthernJoe
NorthernJoe
355
1,356
Northern Ontario
Does this qualify as the fourth time? :)
  • Haha
Reactions: ChadD and TripleB
bumperm
bumperm
1,897
6,774
Gardnerville, NV
Welcome from right here. Just remember, we're all here 'cause we're not all there.
Gravity will hold your battery down, until such time as down is up. Then, if all you've been depending on is gravity, the battery could shift its position, possibly shorting on something in the process, and thus provide a handy source ignition for the fire you just started. There's reason car batteries are secured well - they sometimes go upside down too.
Reactions: ChadD
GROR
GROR
58
241
Castle Dale, Utah
I used webbing and a plastic buckle. Works pretty well and is easy.
20220906 165007 20220906 165039 20220906 165111
Tie
Tie
35
109
Toronto
Thanks in advance!
Eric
I wedged in some Styrofoam and it holds it in place very well.
Tie
