Does anyone have a video on how to change the outer CV boot on P1000 LE? Noticed a hole and am waiting on the part to get here. Any help is greatly appreciated
Clean it good and put some silicon on itDoes anyone have a video on how to change the outer CV boot on P1000 LE? Noticed a hole and am waiting on the part to get here. Any help is greatly appreciated
If a small hole...absolutely.Clean it good and put some silicon on it
Note that to change the outer boot you will have to also remove the inner boot - they do make a device that will allow you to slide a boot over the outer but I have never tried that.Does anyone have a video on how to change the outer CV boot on P1000 LE? Noticed a hole and am waiting on the part to get here. Any help is greatly appreciated
Good to know - I have never hear that - hopefully I will not have a chance to tryYou can replace the outer boot by removing the CV from the shaft. The axle shaft has a spring clip on it similar to the spring clip going into the diff. A swift hit with a hammer will pop the outer CV apart.
I did on the last one..same outer boot...like todd said. Pull the boot clean off grease, punch and hammer to knock bearing and race off the shaft. Easy peezeeGood to know - I have never hear that - hopefully I will not have a chance to try
But @GlockMeister has a outer boot that needs to be replaced so maybe he will take some pics of
Thanks for the "tip" and not the entire shaft!Clean it good and put some silicon on it
Some helpful videos by @joeymt33Does anyone have a video on how to change the outer CV boot on P1000 LE? Noticed a hole and am waiting on the part to get here. Any help is greatly appreciated
