P500 Homemade Glove Box
Chooglin
Made up a glove box ,I still need to make a door for it ,but at least I have somewhere convenient to put my phone now !!!
Gb 1 Gb 5 Gb 4 Gb 3 Gb 2
Moose308
386
289
Nice work and good idea.Get rid of the warning sign.
Reactions: Chooglin
iowaguy
iowaguy
624
1,424
Eastern Iowa
I used a piece of 3/8 thick black plastic the shape of the warning plate and put the warning plate back on it, can't even tell it is there.
272,137
Nice idea @Chooglin !
Reactions: Chooglin
sthomp54
sthomp54
375
Nice work, I really wish someone would manufacture one of these... and leave clearance for the winch solenoid!
Reactions: Geoff
iowaguy
iowaguy
624
1,424
Eastern Iowa
Ya but they would charge $100.00 for it, and we would still end up making our own!!
Chooglin
I originally had mine mounted where the glove box is now (on the factory tabs) !
I had to move it to its current location ,to allow room for the glove box though.
If you look at the frame on the passengers side , there are two existing holes that you can mount the solenoid bracket to and they are spaced perfectly. The only thing you will need to do,is trim a little plastic to allow clearance for one of the bolts (see pic)
This is a much better place to mount it,even if you dont need the room for a glove box.this will keep mud and water from getting on the solenoid when riding !!!!
p500fan
p500fan
417
354
Sand Point, AK
Looks awesome! I can see true craftsmanship in this. My hat is off to you!
Reactions: HUCK
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
That is identical to what i was planning great job
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Well i use metal not plastic just my nitch i could never get the hang of plastic
sporter
53
44
Chooglin - Is the box plastic? Great job, if you want to make another I'll be a buyer.
Reactions: Geoff
Chooglin
What will you charge to make me one? :)
I would love to make you one but the weather in Ohio has been damn cold and my garage is not heated :)
Come spring time, I am going to make a few more and if I am happy with the way they turn out , I will sale them !!!
This being my first one , I see room for impovement. I will be getting a cheap metal break from harbor freight ,wich will make it a lot easier to make these !
Reactions: Willi and Geoff
Ok cool. I'll gladly wait, and me and my buddy will both take one. Yours looks very good!!!
Reactions: Chooglin
Z
zxylene
171
115
Carlisle, PA
Awesome job. Depending on timing and price I will likely take one also. I really want a glove box and your idea is very similar to my thoughts. I mounted my battery seperator on top of the bar that you have your winch solenoid and didn't run any wires in the area as I planned to put a glove box in. I will likely mount the winch solenoid next to the other one as I want a second battery where you have the solenoid.
Reactions: Chooglin
ehart814
ehart814
1,653
3,631
NWPA
it's warming up outside.... :)
