Honda 1000-5 tie down question
Coonir1
9
40
Louisiana
Is it really necessary to tie down the rear of at Honda 1000-5 while trailering?
I double strap the front end using heavy duty straps with tires resting against the front of the trailer. The vehicle does not move and I use tie points that let the suspension function as it should during travel.
67,183
Well. You should always have 4 points.
But you are free to do it as you wish.
When we had atv's they would fit sideways between the rails almoat perfect. We didn't tie any of them down.
5,488
25,256
JMynes posted this is another thread about tying down securely -
Lots of info in that thread -
You want to be this guy.
1657639387364
Not this guy -
1657639590380
Coonir1
9
40
Louisiana
Thanks for the input but I don’t want to be either guy. The first guy strapped the hell out of his tractor but didn’t secure the trailer to the truck. To me that’s more dangerous.
The second guy did not chain his tractor securely, if at all. He also had no front rail to stop the tires from going over the edge of the trailer.
My trailer rail is approximately 18” tall. I’ll be worried about more than my SxS if it jumps said rail while double strapped.
I’ll probably put straps on the rear of my SxS anyway, just wanted to know if it was really necessary. Thanks again for the input CID
67,183
Not this guy -
There is a image of a larger UTV "influencer" group in a similar picture. Rigs flow everywhere.
And there is another UTV group wrecked but UTV's are still secured to the trailer upside down.
Robobrainiac
Robobrainiac
2,564
9,006
Not this guy -
That is a perfectly detailed end result of proper tie down!
stellarpod
stellarpod
821
3,024
OKC, OK - USA
In addition to the ratchet straps over the front wheels, I only use one e-track ratchet strap in the back, hooked to the tow loop at the rear. I only use the cable locks through the wheels and chassis if I'm overnighting on the road.
Steve
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
Steve
Do you use a railroad tie for the gas cans?
WagginTail
WagginTail
1,585
5,880
SC
I mean why not? Only takes a few extra minutes
WagginTail
WagginTail
1,585
5,880
SC
Pics?
-Bear-
-Bear-
NTC Master Fabricator
9,486
102,037
Black Hills, SD
www.facebook.com
  2. Talon X LV
I have a 1000-5 and have had pretty great results trailering it with sunshine and happy thoughts. I also use 3500lbs straps and use 4 points of contact but that is just in case the first options fail. I plan to install wheel straps on my trailer this summer cause that is just the way to go (speed and convenience). In the end, safety first, not only for your sake.
GovtMule
GovtMule
17,495
163,591
Tennessee
I do a heavy ratchet strap over the bar where your elbows would be on both sides. I’ve found that if you keep the suspension from swaying it almost makes it one with the trailer. Much easier to travel at speeds. I’ve hauled a Kawasaki Mule all over the state for work using this method having to haul ass (no pun intended) and it’s solid as a rock. If the suspension sways it makes the trailer sway at speed. Not fun.
Reactions: JenElio
