I’ve got a question in relation to using the accessory subharness. I am about to wire my SuperAtv 3500 black ops winch up along with a digital volt meter. My question is, is an inline fuse needed when using the subharness? Or is there built in fuses already in place on the P5 when using the plug and play harness. The wiring coming off my solenoid to the subharness for key on power, would there need to be an inline fuse there? Also on the volt meter-two prongs off the back a positive and negative. Take the positive to one of the pig tales and ground the negative or run it to the battery. So in short with the subharness is an inline fuse needed when wiring into it or is it protected within the system already? Thanks....and sorry if some of my post and questions over lap. Just want to make sure I wire all this up correctly. Love hondasxs.com it’s a blessing.
