G
I've been accessorizing my new 2016 Pioneer 1000 (bought as a leftover) and gotten a lot of help here on the forums, so this post is my attempt to help some others.
In terms of 'genuine Honda accessories', I've installed the Honda hard roof, rear view mirror and pillar mounted side mirrors, and been very pleased with their quality. More expensive than some third party offerings, but guaranteed fit. (Also did the True battery isolater and Odyssey dual battery.)
Yesterday, I installed the Honda brand front floor mat. Pricey, to be sure, but I figured, hey, I know it will fit like a glove and how long could it take to 'install', five minutes?
First, the quality is excellent - nice thick, durable, rubbery material. Should wear like iron. Even has 'Pioneer' embossed in it. But the install - good grief! Remove the seat bottom. Remove roughly 20 fasteners and the front floor (!). (And you'll be removing more fasteners than the directions state, or the floor isn’t coming out.) Then temporarily attach the mat to the floor, drill some holes, remove the mat, reinstall the floor (carefully, because you need to omit specified fasteners) place the mat, then drill some holes in the floor to match the holes you drilled in the mat (very carefully, so as not to puncture fluid lines beneath), then install the mat and the last of the floor fasteners, plus all the others you removed.
In my opinion, the 'juice wasn't worth the squeeze'. Including confusion and a couple missteps, about 2.5 hours over two days - to install a floor mat! (To be fair, I could do it a lot faster now that I've done it once.) It does look good, and I'm sure it will wear well, but I have one major criticism - Honda punched eight large ellipitical holes in the mat, two on either side of the center hump, I'm guessing because the material is so thick and relatively inflexible it wouldn't have allowed for installation without the holes. But the holes will also allow material to get under the mat I just installed, which can't be easily removed to clean underneath it. Poor design choice, which could have been avoided by choosing a different, more flexible, or thinner material, or heat molding it so it would fit the hump. Or even supplying 'plugs' for the holes.
Were it not for that, I would cautiously recommend it, provided you don't mind the install hassle. But for me, I wouldn't choose this mat again. I'd find another solution.
