H HondaTech Guest Jan 15, 2023 #21 906UP said: While your in there you might as well do the gear mod P500 - A faster P5, it is possible.....gearing increase Click to expand... Unfortunately that is in the rear of the engine, his problem is most likely in the front. Reactions: Buggyman, Rdrcr and 906UP
906UP Well-Known Member Lifetime Member Supporting Member Club Contributor Jul 6, 2017 14,984 142,365 113 da Yoop Ownership 1000-3Talon X Jan 15, 2023 #22 HondaTech said: Unfortunately that is in the rear of the engine, his problem is most likely in the front. Click to expand... Agreed but that wouldn't stop me Reactions: Buggyman, Rdrcr and Backwoods
DRZRon1 Well-Known Member May 11, 2019 1,415 4,352 113 PA Ownership Talon X Jan 15, 2023 #23 pulled shift motor apart - magnets busted and grinding trying to spin - thought was onto something simple bad news - only shifts up, its in 5th now and won't go down - we have it on jack stands rocking the wheels back and forth trying to downshift not good Reactions: Buggyman and Smitty335
DRZRon1 Well-Known Member May 11, 2019 1,415 4,352 113 PA Ownership Talon X Jan 15, 2023 #24 took a coffee break - went back at the rocking and got it to down shift to 1st ordering up a shift motor and will see what happens thanks for the wisdom - not sure this thing will be out of the woods with the shift motor Reactions: Buggyman, Smitty335, Rdrcr and 1 other person
DRZRon1 Well-Known Member May 11, 2019 1,415 4,352 113 PA Ownership Talon X Jan 20, 2023 #25 I give - outta talent shift motor arrived today I was working, my buddy swapped it out, nada I got out for a few minutes to check, pulled shift motor off - ran to a good 12v battery, no spin…… Seems that motor is no good went to get that machine out of my garage and put on his trailer cause I’m sick of looking at it in 1st gear dies when trying to pull out - eventually drug it with my atv to his trailer no solve Reactions: Buggyman and Smitty335
DRZRon1 Well-Known Member May 11, 2019 1,415 4,352 113 PA Ownership Talon X Jan 27, 2023 #26 solved new shift motor plus wiring harness was jacked\rubbed - repaired back in action Reactions: Buggyman, 500oneer, Dave75 and 4 others
906UP Well-Known Member Lifetime Member Supporting Member Club Contributor Jul 6, 2017 14,984 142,365 113 da Yoop Ownership 1000-3Talon X Jan 27, 2023 #27 DRZRon1 said: solved new shift motor plus wiring harness was jacked\rubbed - repaired back in action Click to expand... Thanks for the follow up, congrats on fixing it Reactions: Buggyman and SILVER_ALERT
