Honda p500
Shawn7109
5
Ga
Hay guys had a few questions about my p500
Shawn7109
5
Ga
Like what? And welcome!
Thanks I had to replace my fule pump on my p500 cause I got in some water .do u think it could of messed up the injector also cause it still want start
Shawn7109
5
Ga
Did you drain and replace all the fluids? Change the spark plug?
It didn’t get any water in the engine just got in the tank and killed the fule pump cause the vent hose on the tank was not vented long enough I changed the fule pump and I can start it with with start fluid and the pump is new and is pumping but won’t run with out using starter fluid
Shawn7109
5
Ga
I did change the spark plug also
Shawn7109
5
Ga
Check the power to the pump. Is there water in the airbox at all?
No water in air box the pump is pumping but I pulled the injector out of the throttle body and it is bearly spraying any fule just a tad
