P1000 Key On Power, Illumination, and backup source! - 2016 through 2021 Honda Pioneer 1000 Only
66,870
According to Honda Accessory Instructions. Here is the recommended location for Key On Power for the Honda Pioneer 1000 Side by Side!
Honda suggest tapping the 15A Acc Fuse on the output side. Here you will find 2 WHITE with a BLACK STRIPE wires coming out of the output side of the fuse. You will need to untape the wire bunch to access them. It is recommended that you use a posi-tap (not shown) vs the wire tap-ins (shown) for a better error free connection.
IMG 6647
1000 key on
IMG 6658
66,870
N
Ned
241
183
West Kentucky
View attachment 8398 View attachment 8399 View attachment 8400
Thank you for that information. I hope those watching in Electrical help see it.
Reactions: Hondasxs
ghost
ghost
993
1,873
BC
Yeah, this is awesome. Thanks
ButchersHook
ButchersHook
167
332
For those who have the kfi winch mount, on the back the their install instructions it also shows that you should use the 15 amp black white acc wire for winch control power. Also shows best ways to mount the solenoid and where to run power wires.
Not sure why they included in with their winch mount but was helpful when i installed the superwinch.
Springer
Springer
312
234
Good to hear. I just ordered he KFI mount and Superwinch Terra 4500, so getting these instructions will be right up my alley!!
Kenjones21
Kenjones21
165
107
Central Louisiana
Honda SxS question for you, The wire harness for the keyed power has some form of clip holding them down , couldn't get a good look at them last night but do they just pop out are is there secret to getting them out.?
Reactions: Denalidude
F
fredlp6582
Thinks, iam fred from golden valley AZ.what does the posi-tap look like, I have the tap-ins.
66,870
Here is the correct location for Back up / Reverse power according to OEM instructions for the backup alarm for the Honda Pioneer 1000.
The amp rating for this wire is 15 amps combined including all other items tied into the 15amp "Acc" fuse.
Location includes a positive and a ground trigger.
The WHITE/BLACK STRIP is positive and is "Key On" and can also be used as a Key On source near the rear.
Second wire is GROUND TRIGGER is only active when in Reverse! Be careful, this will read funny with a test light. Test it while in reverse for ground!
Unfortunately, It is a little difficult to access.
Here is the back-up alarm instructions for more details - P1k - Back-Up Alarm Harness - 08Z76-HL4-A00 - Instructiosn | The Honda Side by Side Club!
This plug can been seen by looking up and under just in-front of the rear drivers tire. Looking towards the oil filter and on past to the frame you will see a un-used wire. It will be 2 wires with a white plug.
The plug is sealed with a plug. See back-up alarm harness instructions.
Here are some pictures from a Pioneer 1000-5.
IMG 6763
IMG 6747
Whiskey1
Whiskey1
131
Arizona
Positive is "Key On" and can also be used as a Key On source for the rear.
Ground trigger is only active when in Reverse!
Here are some pictures from a Pioneer 1000-5. View attachment 8557 View attachment 8558
This is excellent info! I'm going to hunt down that wire and install LED reverse lights! Thank you.
rcarroll
9
Does anyone know if there is a reverse trigger wire I can access in the front so I don't have to fish a wire up from the back?
Reactions: dotman1
Springer
Springer
312
234
I used this info to wire up my backup lights. I chose to have them come on when in reverse, regardless if the headlights are on or not as long as the ignition is on. I was able to simply use the two wires as hot and ground, and ran them to the lights. Easy peezey.
Thanks HONDASXS, your my hero!
rubicon05
rubicon05
234
310
Southern, IN
What wires did you tap into? This is exactly what I'd like to do. Thanks
Reactions: biesty
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I have a big heart and care about everyone... even grumpy old men! lol I guess Buffett said it best, "if we couldn't laugh, we'd all go insane".
Reactions: Tabascojunkie
