P1000 Honda Poly two piece windshield - Not sure I like it
mfinity
12
35
So I installed the Honda Poly windshield two piece yesterday.
First off the center support for the wind deflector center doesn't fit/work/etc. I viewed one youtube video with the same issue - see the image below for that bit. No matter how I messed with the fitting/placement - there was going to be a near 1"inch gap between the deflector and this center support bracket - if you've installed one - i'm sure you know what I mean. Not sure how Honda got this so caddywompass. Right now I don't have the bracket connected to the winshield - will have to fabricate something or other.
On to the longer term topic - which is Does anyone wish they had just gotten a one piece unit? The fiddly side brackets, the black seal across the wind deflector, just the entire thing fills me with regret. But now it's on the vehicle. And it's cold out - if it were hot out I may appreciate the split-screen option. Not sure.
Thoughts?
-m
Reactions: BWAF and sharp
Thoughts?
-m
Yeah, I had their two piece on my old 700 and hated it. I have the one piece on one of my 1000’s and it’s great. That bracket you highlighted fits perfect..
allgm1
allgm1
1,049
1,484
New Hampshire
I can't speak much for the windshields on the p1k's, but I can tell you the 700 windshields aren't much better. The rubber seals are a joke, the ones on the side of the upper portion hung around for the first year then shortly after that they became litter out on the trail somewhere. And if you ride in the rain, the water will run in under the fixed lower portion, down the dash and onto my leg. But I remind myself that it is an sxs,not my truck and a little water and breeze is par for the course so to speak.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thoughts?
-m
I did see that video and like you was concerned! I did however have a deflector mounted prior to installing the Honda OEM 2 piece windshield. The center bracket lined up perfectly with no gap. If you take pictures of the lower section I’m sure the problem will be evident. I will try to get some pics of my install later.
It’s later...
3DDB06CE F94F 4308 BB61 A62BA6D1ADAC 2F510018 1B98 4CA3 A182 891E5C12264C 82868A32 8B65 4AF4 9819 2773450151A1 C025DC3A 0480 4286 B18D BCB3AE8AAB7A 0D1FF537 0464 4F64 8EFD BE9E93FFED54 1519788C 8CCF 42E4 9BF1 C5A10B0AF1FE
mfinity
12
35
Perfect as in perfect or Perfect as in = No it's a piece of crap? Sorry I'm assuming sarcasm because mine is so far out of whack.
Reactions: TimG and sharp
mfinity
12
35
Yeah - I took the side seals off - manual said keep them if installing a full cab- which i'm not. So they are in the garage currently. Not happy about that water run-off you are reporting. Will see what happens with this one. It does kill the frigid wind - which is great.
Reactions: sharp
108,167
I’m not home right now but it can take a pic of that bracket when I get home if you like? My .2cents on this windshield. I like it for what it is. The machine is not an automobile. That said it’s not gona be perfect. If your patient you’ll get it to fit correctly. There are some windshields that fit dam near perfect if want to spend the money.
Reactions: Vikes79 and TimG
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Ok thanks. I really did fiddle with it quite a bit. Not sure then. Stumped.
Mine was a little off..so i put a thick rubber washer between the windshield and middle support. Other than that it has served me well for almost 3 years
And remember, ours is on a one piece windshield, not the two piece. There may be a difference, and it will be nice when others with two piece windshields chime in on this for you..
hoghead76
hoghead76
1,159
6,179
oklahoma
20181121 171552 20181121 171503 20181121 171417 20181121 171359 I have the two piece it fit fine for me.
If you can get pic maybe see if can help.
Its hell when thing don't work the way that should.
mfinity
12
35
I went back and messed with it - closed the gap to the point before the deflector would bow in/kink. It's ok at this point. Gap on inside is about 1/4" - and that will suffice. Thanks for the help!
1BadDart
1BadDart
1,241
10,813
W. KY
I wound up using some spacers and a longer bolt on the center support on my two piece windshield.
