Today Honda released the full specs behind its flagship adventure bike, The Africa Twin CRF1000L. This new bike features a 1000cc parallel twin, 6speed, DCT engine boasting 93.87 hp with 72.3 ftlb of torque from factory.
So what does this have to do with the Pioneer 1000?
It is said to believe this is will the same base line engine that will be found on Honda's Flag Ship SxS the Honda Pioneer 1000! Though it will be altered with different transmission setup and other specific specs, the overall combustion engine design is should be relatively the same. We believe this shows the trust Honda already has behind this design.
Of course my immediate questions is... Will the Africa Twin top end easily transition over to my P1K?
Africa Twin CRF1000L Specs!
- Engine Type Liquid-cooled 4-stroke 8-valve Parallel Twin with 270° crank and uni-cam
- Engine Displacement 998cm3
- Max. Power Output 70kW/7,500rpm (95/1/EC)
- Max. Torque 98Nm/6,000rpm (95/1/EC)
- Bore & Stroke 92.0 & 75.1mm
- Clutch Wet, multiplate with coil springs, Aluminum Cam Assist and Slipper clutch
- Final Drive O-ring sealed chain
- Gearbox / Transmission Type Constant mesh 6-speed MT / 6-speed DCT with on and off-road riding modes
- Honda Selectable Torque Control System (HSTC) * HSTC 3-levels + Switch Off (*ABS & DCT models only, not on STD model)
- Frame Type Steel semi-double cradle type with high-tensile strength steel rear subframe
- Turning Radius 2.5m
- Dry Weight 208kg (STD), 212 kg (ABS), 222kg (DCT)
- Kerb Weight 228kg (STD), 232 kg (ABS), 242kg (DCT)
- Fuel Capacity 18.8 liters
- Length x Width x Height 2,335 x 875 x 1,475mm (STD), 2,335 x 930 x 1,475mm (ABS/DCT)
- Wheelbase 1,575mm
- Seat Height (STD position / Low position) 870/850mm
- Ground Clearance 250mm
- ABS system type ABS* 2-Channel with rear ABS off switch (* ABS & DCT models only, not on STD model)
- Brakes Front 310mm dual wave floating hydraulic disc with aluminium hub and radial fit 4-piston calipers (*ABS) and sintered metal pads
- Brakes Rear 256mm wave hydraulic disc with 2-piston caliper (*ABS) and sintered metal pads. Also Lever-Lock Type Parking Brake System on DCT model.
- Wheels Front Wire spoke with aluminium rim
- Wheels Rear Wire spoke with aluminium rim
- Rim Size Front 21M/C x MT2.15
- Rim Size Rear 18M/C x MT4.00
- Tyres Front 90/90-R21 tube type
- Tyres Rear 150/70-R18 tube type
