P1000 Honda split windshield vibration
ronbarn
6
Texas
Have Honda OEM split windshield anybody have ideas to stop vibration when open? No support in middle
Reactions: Isaiah
Vikes79
Vikes79
SKOL!
11,776
114,183
South Dakota
  2. Talon X4 LV
honestly...it’s a airflow problem.
A stiffener across the face width wise to minimize the deflection is about the only other solution.
I just drive and ignore it...but I only use my windshield in the spring / winter.
Reactions: Isaiah
rickoshea
i haven't noticed any vibration on mine,but i have my rops clamps on really,really tight.it was a real bugger to get it all lined up and i didn't want it to shift.i pushed it out at the bottom center and then clamped it and adjusted everything from there.i did get a squeak at the top left corner,but a piece of the soft side of some hook and loop stuck to the cage cured that.
SCA
85935
I used a piece of 1/2X1/2 aluminum angle across the window at the lowest part of the window before it angles out to to meet the lower window. I used 1/8 in pop rivets to attach it.
ofrcboy
ofrcboy
507
589
Oregon
I made a wood brace for mine with a v on 1 end for mine, problem solved
