Talon Honda SXS Store Product
Talonpalooza
Talonpalooza
122
237
I just want to give a shout out to the HondaSXS store. I have ordered a 5 pack of the accessory connectors for my Talon. I have used two of them and work great for my Talon. Also, ordered the jumper connector for the seatbelt bypass. Had a little quality hiccup. That day, no questions asked, a replacement was sent no charge. Due to that level of Customer Service, I ordered a rocker switch connector to try.
I am in manufacturing. The true test of how good a company or service is, is when things go sideways. How are you treated after the sale. And I just want to say, the Honda SXS store is top notch. I would suggest all of you patronage the store.
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
The seatbelt hiccup is a bit of a pain. Many people have not ordered the correct machine. I believe @Hondasxs has changed the listing a bit to help identify which machine you are ordering for.
Reactions: Mudwing
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
We had a member purchase a light kit and install it.
He was having problems with it and came to the check in table at Takeover to try and get some help. @Hondasxs wasn't around to take care of him. So we simply grabbed a few test lights and made the corrections to his machine to get him on his way. It was a simple mis-wire of a plug. The member was unsure on how to re-pin the harness, we made the corrections and sent him on his way.
66,870
Thanks man.
I seen you other order yesterday. I already packed it and fixing to print the label.
Here is a few links to the items mentioned.
Harness accessory seat belt bypass kit - Honda Talon 1000 R, Talon 1000 X Side by Side! HondaSxS
Honda Talon 1000 R/X Quick Switch Connector for OEM Wire harness.
Honda Talon Switch Panel Accessory Pigtail. DIY
Talonpalooza
Talonpalooza
122
237
Sent the right jumper. Just one of the leads came out. Again, not a big deal, I fixed it, but I was still sent a replacement.
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
Awesome! The bypass listing at one point required the customer to choose the machine and most would default to Pioneer. Couple people have complained on Facebook and blamed the store vs admitting they didn't choose the correct machine. It appears they are separate listings now. Which should help with the confusion.
