Honda tune up time
john790
367
1,105
Clinton ohio 44216
Well iam in the middle of seasons now time for valve adjustment.I will need pucks to adjust intakes right.While iam in there should i replace inj wiring and pull shift motor and blow out the dust.Plugs its a 2020 with 700 miles.If you look a New York this thing might have a bad winter main plowing unit now.I will ck grounds while iam in there.Anything else would be helpful.
115,818
You dont need to do all your asking about with that low of milage. Shouldn't have to worry about that injector plug with your year. Plugs will be just fine. Just change the oil & oil filter pm and check your air filter and change it if need be.
your far away from the rest of what your thinking of doing. Hell, an oil change might be a Stretch right now.
Bighat
Bighat
887
3,795
Gallipolis Ohio
I read a piece a while back and the guy was a cattler farmer out west, must have been in big country because he put over 20,000 mile on it and never did nothing but change the oil four times. Never ever put and air cleaner on it. Not saying you should do this but no since in overkill. Just flow the maintenance schedule and it should run forever, it's a Honda.
Bombardier Convert
Bombardier Convert
329
1,121
Minnesota USA
I have 1200 miles on my '21 PK-3 and I have changed oil twice so far. That's it. It runs like the day I first got it, maybe even better cuz it's broke in.
john790
367
1,105
Clinton ohio 44216
In my past with new Hondas seemed valves were a little tight on first adjustment.After first adjustment they were always ok after.A little loose does not worry me just not tight.
tdhanses
tdhanses
1,044
3,553
Kansas
I believe 99% of those that have checked have found them to be in spec.
