P1000 Honda upper doors -
Rubicon20
20
74
Indiana
Anyone that has the factory Honda doors - the nutsert that you put in door to hold doors down sits crooked and it’s damn near impossible to get that bolt started - any secrets or tips that will help? I’ve had them on 2 of Pioneers and struggled with both -
Reactions: Smitty335 and ChadD
116,574
any secrets or tips
Lots of cursing! 😂
seriously, lots of cursing.
If u lined up and drilled and aren’t lined up, your kind a fubared and have to man handle it to get it lined up. Dont grunt too hard or youll get a hernia 😂
Got any pics of the situation? It will help to maybe do something different
P
PDogRex
72
350
Central MT.
Have same problem on my P1K5, the top of the door is sloped (not level) and when setting the nutsert it is angled.
I tried pulling out on top of the door frame and then trying to start the bolt no luck.
Sure would be nice to find a solution for this poor design.
Rubicon20
20
74
Indiana
I don’t mind the Honda doors - I just hate this part:). I was thinking about making the hole larger on the door frames so I have a little more play to see if that may help some. They will stay on without this bolt but I’d like it to be correct -
21,759
93,330
What generation doors do you have?
I have first gen, takes minutes to mount to the door.
Change the lower bolts to a longer bolt. thread them in a few turns then attach door.
Attach the pull handle, cinch all 8 bolts down. Takes minutes. With the keyholes on the mount, it goes real easy.
Rubicon20
20
74
Indiana
Both sets have been 2nd gen doors. The 2nd Gen only take seconds to take off if you can get this bolt to work easily
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I ran into the same problem with mine when I installed them. I ended up just carefully drilling out the aluminum on the window frame to a bigger size to help with installation. It really doesn't matter that it is bigger hole, it just allows it be installed easier and keeps the upper to be pulled down just the same. When I installed a set on my friends rig later I paid a little more attention where to drill the hole for the rivet nut and his is easier to put on.
TripleB
TripleB
20,992
182,873
Caryville, Tennessee
I did the same to my door frame.
tjoreo
tjoreo
1,032
1,992
Southern Idaho
There is just enough angle to the top of the door that makes it tough unless you mark it and drill it in the right spot. There is alot of time I don't even put the thumb screw in because it might be 10 degrees 1 day and 60 the next around my place and I take them off and on.
TripleB
TripleB
20,992
182,873
My thumb screws are a thing of the past. They popped off and I have to use a allen head socket now
Wisco pioneer
Wisco pioneer
45
205
Do any of you trailer your buggy with the doors on?? I know it says not to buuuut.
Reactions: ChadD
tjoreo
tjoreo
1,032
1,992
Southern Idaho
I regularly trailer mine with the doors on and haven't had any trouble. I have the 2nd version with the front plastic clip so I just make sure the frame is where it is supposed to be. I do have the rear gullwing doors so I run a bungee cord to both doors window strap to keep them closed. So knock on wood no trouble yet
Sent from my SM-G781V using Tapatalk
Wisco pioneer
Wisco pioneer
45
205
Good to know!! I have the 1000 3, just put doors on a couple weeks ago, haven't had to trailer yet but I figured it would be ok.
