P1000m5 How many amps can we draw continuously?
CMH
CMH
25
42
Montana
A bit off topic, but electrical system related. I was doing my research looking at what kind of winch I want to go with. All of the usual suspects have an enormous draw at full load. I am completely aware this is not a continuous draw. But if you are in a tough spot, at the full load line speeds they report, I could see there being at least 5 minutes of winch time. With the puny batteries these have and the stated 600W alternator output, can I really only run my winch for a minute or 2 at a time at or near full load? That doesn't seem right - actually I feel a little foolish even typing it. What do folks actually running this setup have to say? Seems like I am missing something here, but I can't put my finger on it... Or is a second battery setup in my future, even with a fairly mild bundle of other accessories?
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
I think you have an excellent grasp of the situation. YES! full load amps on a 4500 lb winch will draw your battery down. Keep the vehicle running and you can run the winch twice as long. Ultimately, the dual battery set-up is the best. That way if you run the battery too low your cranking battery is still charged.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
This guy is right. I would also add that I have very rarely just winched at full load. With a machine weighing in at 1500 lbs you've got a long way to go to be at full load/amp draw.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
1700 something wet plus in my case at rrb, 200# gear (beverage cooler and something else.. whatever lol), 200# mud, could have 400# passengers and 200# accessories, winch, tires, bumper, lights etc... 2700#.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Didn't even account for myself and a front passenger. Could be another 400#. 3100#
Reactions: Koda
CMH
CMH
25
42
Montana
I have been stuck enough in a 5,000lb truck to drive an 8,000 lb winch to a standstill. However, now that I think about it, that is probably not going to happen very often, so maybe I am overthinking this, at least to the point of having a full load on a 4,500 lb winch very often.
Reactions: Koda and JTW
K
KenThompson
280
622
Mulino
So, on my Talon, how many amps or watts can I continuously draw to run lights, etc without draining my battery?
67,653
At the optimal RPM's.
50 for Pioneer's
58 for Talons.
Then total then the stator cant keep up.
Sorry, I don't know the optimal RPM range.
Reactions: Haldog77
K
KenThompson
280
622
Mulino
Wow! That seems like a lot of amps. Thanks for the fast response!
Reactions: GWH
K
KenThompson
280
622
Mulino
Honda service manual says the stator will put out 15.5 volts at 5000 rpm.
67,653
Well... if that's where the .kw output is rated at then it needs to be recalculated.
I caculated the following off 12v's.
.6kw = 50 amps for Pioneer
.7kw = 58 amps for Talons.
If we change it to 15.5v's we get this.
.6kw = 38.7 amps for Pioneer
.7kw = 45.1 amps for Talons.
