P1000 how to use stock lights (stock headlight switch) to turn on plate lamp and lighted switches without cutting factory wiring
RogerD
14
Hurricane wv
I am looking for a harness or connectors to make a harness that will allow me to power up my license plate light and my lighted switches when the headlight switch is turned on. I would rather not cut into factory wiring. I would like a sub harness that is similar to the one in the honda sxs store that allows the high beam to trigger aux lighting or a place to source the connectors to make a harness. Any help or helpful thoughts would be appreciated.
thank you in advance.
Reactions: CID and Isaiah
Neohio
Neohio
Beast of the East
17,909
86,473
Painesville Ohio
Did you look at this harness?
It will supply power as soon as your ignition switch is turned on.
I understand wanting to use the headlight switch. @Hondasxs might be willing to make a one off if you ask nicely.
I would be careful about using the headlight switch though. I don't know how much load that circuit can take without an additional relay.
Reactions: Mudwing and Isaiah
AZRocks
AZRocks
111
217
Phoenix
There are options for the license plate light. My kit was an XTC kit designed for a razor that works on the pioneer. The sales tech when I bought the machine recommended it. But it would be easier and cheaper to just go with a simple lighted plate holder and tap into the rear light harness. Get used to cutting into wires, drilling into metal and plastic, and cutting holes on these things if you are going to upgrade with non-OEM equipment.
As far as lighted switches, mine are lighted at power on. You don't notice the switches are lighted until it gets dark. But.....you could run all the switch light grounds to a relay connected to a headlight wire for activation.
Reactions: Isaiah
HondaTech
Hacking into stock wiring sucks, but is sometimes the only way to achieve the desired results.
If possible I always splice into the switch side of the plug or device so that the main harness is undisturbed.
The light switches shouldn't be difficult, and the license plate light could be run off the reverse alarm wire in the rear of the machine, one of the two wires there is powered key on, the other is grounded when in reverse.
Reactions: RogerD and Isaiah
RogerD
14
Hurricane wv
Thank you. I have that already. I just don’t want my plate light to be on during daytime driving.
Reactions: russknight
russknight
russknight
1,910
7,511
Perry Florida
@Hondasxs might fab one up for you. I hear he is a pretty sharp dude. ;)
Reactions: Isaiah
RogerD
14
Hurricane wv
Ya. As long as its not a LE.
But my schedule is kinda of tight currently.
It is a deluxe. I didn’t realize there wud be a difference. That is interesting.
If I could find the connectors, pins and I could Probably make The sub harness
Reactions: Isaiah
67,230
LE uses a rocker switch vs a dial.
LE Switch controls HIGH and LOW only. Tail is out of the fuse box for some reason.
The Deluxe with the turn knob controls High/Low/and TailLights.
Below is the connector you need. The brown wire is your target.
russknight
russknight
1,910
7,511
Perry Florida
He will need a double crimp tool such as this also.
RogerD
14
Hurricane wv
Thank you guys this is most helpful. I just didn’t like the idea of my switch lights or my plate light being on during the day with just using the key on power or trusting I wud remember to cut it off during the day.
Reactions: Isaiah
I purchased 3 led lights and rocker panel switches
It looks like the lights pull 11.25 amps. It doesn't look as thought the pre made wire harness will work. Is there a way I can still someone turn them off with the ignition?
Thanks in advance..
Use the premade harness above to control a relay that feeds power to a secondary fuse block. Honda has not provided any additional circuits, they will provide you with a $300 accessory harness that will connect the honda factory accessories but you have to hack it up to make it work with aftermarket.
Your best solution is to make your own or buy one from @Hondasxs if you aren't using factory accessories.
Reactions: Isaiah and TripleB
AZRocks
AZRocks
111
217
Phoenix
Thanks in advance..
The 180W lightbar plus two 60W cubes is 300W / 12V = 25 amps. The harness should work fine. What makes you think it won't do? Connect the relay to an ignition source and the lights will only work when the key is ON. Connect the relay to a headlight wire and the lights will only work when your headlights are on. Connect the relay to the battery and they will always work when switched on.
hartleyjohn73
Lincoln, mi
I didn't think it would work, because in the description is says
Max Amps
- Pioneer models
Recommend no more than 8 amps max load. This circuit belongs to the 15a ACC fuse circuit and is split between the accessory (cig) plug and the backup alarm/light port.
AZRocks
AZRocks
111
217
Phoenix
Max Amps
- Pioneer models
Ah! Not an issue. You would wire the 25 amps of lights directly to the battery. The relay would connect to the 15a ACC circuit (any ignition ON source), but a relay only draws about a .25 amps to close the relay and let juice from the battery flow to the lights. The relay pictured is rated for 40 amps draw. You may consider picking up a second harness/switch if you want to run the pod lights separately.
Reactions: Lady01
Brut
Rising sun
I'm basically trying to do the same thing. I want to use a factory headlight switch to control my light bar witch has high/low beam and get the switch to illuminate when the key is turned on just like the factory installed one. I'm just not sure what wire does what
Reactions: Lady01
