I don't have power on accessory package vehicle plug in
santacruz2023
10
Monterey
I'm connecting some fang lights and they don't work. I checked the voltage and I don't get any power. Hopefully you guys could help me.
It's a 2023 honda talon 1000R-4 fox live valve
I'm attaching a picture of the plug I'm talking about
PXL 20240607 030713120 PXL 20240607 030718699
This is the plug I'm connecting to the OEM plug
I'm attaching a picture PXL 20240607 033131057
Reactions: TxDoc
TxDoc
TxDoc
1,711
5,963
TEXAS 🇨🇱
photos.app.goo.gl
Have you checked the wires before they enter the plug? The plug may have a broken connection or you could have a fuse out.
Sent from my motorola edge plus 2023 using Tapatalk
santacruz2023
10
Monterey
I checked both plugs they look good. Do you know what fuse is for that plug
PXL 20240607 162700926
Reactions: TxDoc
109,632
Welcome from Michigan!
Sounds like you need to get power from a different source. I wouldnt advise getting it from there. If you dont have some sort of a switch plate with a fuse/relay set up or a second battery set up to get power for accessories from, I would recommend going to the club store and get set up. These rigs like clean power to run the daily working of the rig.
Also when u get a chance, post some FULL Pics of your rig. After all Its Rule #4😉
Reactions: TxDoc
Hello_Darkness
Hello_Darkness
41
186
Just to the right of nowhere
Hello_Darknees thank you I check the fuse box they all look good.
That plug in your picture, as well as the blue 2 pin plug near it and the accessory socket in the dash all get power from ACC1 fuse.
They should only have power when the key is on
Does your Accessory socket in the dash have power?
santacruz2023
10
Monterey
ACC1 is good. I do have power in the accessory socket the rear. I have not checked the front one. Maybe I'm just going to get a wiring harness. I would like to just use the OEM plug. Let me know your thoughts why that plug is not getting power. Thank you all for the help.
64,739
Polarity is reversed. This is a common issue. Pioneer 700 is the opposite for this same connector.
Match Red to white
and
Black to green.
Stand by for a video on how to repin your connector.
Hello_Darkness
Hello_Darkness
41
186
The rear accessory socket is power off ACC2 fuse, if the fuse is good and you have battery power on the fuse then it has to be a wiring problem.
Do the factory switches on the dash light up with the key on?
Hello_Darkness
Hello_Darkness
41
186
Match Red to white
and
Black to green.
Looking closer at his picture, this appears to the problem, his lights are pinned wrong
Santacruz2023 The white wire on the Talon harness is power
