Ok so I have a 2011 Big Red and have a weird thing going on. Just a little background probably 2 months ago I had to replace the camshaft the exhaust side lobe was almost round. Replaced it ran like a champ, the other day I it began not wanting to idle when you first crank it up it almost had to warm up before it would sit and idle no big deal. Well then once you put it in gear and start driving it was fine but when you let off the gas and almost come to a stop it cuts off. It only does this sometimes, you can turn the key off turn it back on and it may not do it again the whole day, but it may do it all day its weird. I replaced the IAVC thinking that was it for sure but sure enough it still does it. Unhooked the battery for a while hoping to reset everything and still does it. I feel like it has to be an electrical/computer issue being you can start it right back up everytime and its so unpreditable. Oh, and will the valves being out of adjustment do this? Any help would be appreciated thanks!
