P700 Idling problem HELP
43,588
Looks like it...
Screenshot 20191007 204633 Chrome
Check to make sure the screen isn't clogging.
Reactions: Russ989
Dylan23
34
38
GA
  1. Big Red
Ok I will check it when I get home today thanks for all the ideas. What would cause that spark plug to foul up so quick I mean it ran maybe 10 minutes total and that sparkplug was bad fouled up??
Dylan23
34
38
GA
  1. Big Red
@DG Rider Do you think I need to check compression? I dont have a gauge but could get one if you think that would that help solve some of this?
Reactions: DG Rider
43,588
Can't hurt. Be warned that the compression specs are low (like 90 psi or something). Check it with the battery full charged and the throttle wide open.
EDIT: the spec is 80psi.
Reactions: Russ989
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
what about the fuel injector?. my dads big red was reading 30-40 on compression check and still running ran like crap but still ran.
Reactions: Mudwing
Dylan23
34
38
GA
  1. Big Red
Ok guys just a little update picked it up from the shop this weekend.Guy said that some wires going to the throttle body were crimped and throttle body needed cleaning out. I thought I traced every wire in there but guess not. Shes running like a champ now!
F
Fishi812
7
IL
So is the revving idle normal I am looking to get a 2019 700-4 and it revs when idling in neutral. When you put in drive it run fine no revving HELP
